#61
Of course you would be running injectors; not like 2v7 would work without the injectors. I believe 14 lbs is just more than the engine will want to run without internal modifications. You would at least need cams and likely need pistons to run 14 lbs on gasoline.
On the stage 1 question no you can't make that assumption. The nock sensors can learn the adjustment for whichever gasoline you are using. Don't worry about the details of the programming; I have it under control. The question that was asked about running the e85 code with a high octane gasoline...absolutely not...it wouldn't even start. |
#62
yes the idea is that there should be a lot to be gained. There will be a dyno plot to show the full throttle gains before shipping.
#64
Stage1v5 first time purchase $219
Stage1v5 upgrade $79 Stage2v7 or Stage 2v7f first time purchase $399 Stage2v7 or Stage 2v7f upgrade from v6 free with $20 shipping and hassle for a limited time Stage2v7 or Stage 2v7f upgrade from prior stage 2 versions $129 Stage2v7 or Stage 2v7f upgrade from stage 1 $199 Maf meter harness $30 Maf meters and fuel injectors will not be carried. |
#66
How long is this limited time for us V6 guys? Also, I'm still hanging on for this larger injector mod...
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) ![]() socaleuro.com They like the flat 6... Check My New Homepage.. |
#67
Which fuel injectors are need for 2v7?
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles ![]() My WRX's Cardomain Page |
#68
Alright I guess this is a stupid question because power is power but If I still
have the stock gears in my car should the 1v5 still produce a noticable difference? |
#69
nissan sr20det 370cc injectors. They are from four cyllinders so you have to get two sets. If you start looking at pictures of nissan injectors you will notice that some have a big bottom oring and some have a small bottom oring at almost the very end of the injector. The ones with the small oring at the end of the injector are the ones that match our fuel rails. They have been going for right around $70 for a set of 4 on ebay.
It will start when we start shipping 2v7 and will last a few weeks....say to the middle of january.
Yes, there will be dyno plots of wide open throttle performance before shipping.
Even with fine tuning it is very hard for us to run 12psi... 14 is out of the question without race fuel and/or internal work...which includes pistons, rods, cams,lifters, springs...the list goes on and only gets more expensive as you continue ![]() Tom |
#74
