Old 11-20-2006, 04:23 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Timken Wheel Bearing Assembly
I saw this on e-bay (Item number: 110055680200). Is there actually a wheel bearing assembly for the SVX? No need to press in bearings ever again? I know the newer cars have the one piece assembly. Is this something new for our cars?
Old 11-20-2006, 04:51 PM
Speedklix's Avatar
Locker Link Solution
It is still a bearing that needs to be pressed in.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-20-2006, 07:50 PM
dannmarr's Avatar
I work for my SVX
Why does the photo and description indicate an essembly? (Not a bearing alone).
Old 11-20-2006, 07:57 PM
Speedklix's Avatar
read the text immediately below it
-Mike
[SIGPIC][/SIGPIC]
Old 11-20-2006, 08:17 PM
Speedklix's Avatar
It is very cookie cutter... does not even mention if it is front or rear
-Mike
[SIGPIC][/SIGPIC]
Old 11-20-2006, 08:47 PM
dannmarr's Avatar
I work for my SVX
too bad.
Old 11-21-2006, 07:47 AM
Earthworm's Avatar
Meow!
It did say rear wheel.
Old 11-21-2006, 06:28 PM
Speedklix's Avatar
Way to point that out Dave
I can't believe I read that and it didn't even register
-Mike
[SIGPIC][/SIGPIC]
Old 11-22-2006, 07:51 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Assembly
As noted, it is call an assembly because it is an assembly. For each wheel there are 2 bearings and one race.
Old 11-22-2006, 10:21 AM
dannmarr's Avatar
I work for my SVX
The photo is misleading, it shows the bearings with the hub assembly.
Old 11-24-2006, 09:33 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
one member did manage to find a true assembly for pretty cheap too but who knows what quality the bearing it houses is
- John
