Timken Wheel Bearing Assembly
I saw this on e-bay (Item number: 110055680200). Is there actually a wheel bearing assembly for the SVX? No need to press in bearings ever again? I know the newer cars have the one piece assembly. Is this something new for our cars?
It is still a bearing that needs to be pressed in.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
Why does the photo and description indicate an essembly? (Not a bearing alone).
read the text immediately below it
It is very cookie cutter... does not even mention if it is front or rear
too bad.
It did say rear wheel.
![]() ![]() I can't believe I read that and it didn't even register ![]()
Assembly
As noted, it is call an assembly because it is an assembly. For each wheel there are 2 bearings and one race.
The photo is misleading, it shows the bearings with the hub assembly.
one member did manage to find a true assembly for pretty cheap too but who knows what quality the bearing it houses is
