New Brake Rotor Option (very nice)
Just picked up finally a new rotor line
We are still going to be keeping our other line of rotors (they have been great so far with prices and quaility) but for those maybe wanting to go a step Up there will be about a 6 choice option from these guys: http://www.dba.com.au/default.asp and Ill be stocking some of the midrange priced units, while being able to get all of them. I know their prices are more, but think the Svx owners would like more options for the hardcore guys.. Ill have more info soon
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
I really like these...
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
Very nice!
Back when I was looking for rotors, I wanted to get some from dba, but I couldn't find a good place to order them through. Glad to see you'll be carrying them.
drool.... two piece rotors that I shouldn't buy...
Better venting
I love their venting design!
They call their internal venting Kangaroo Paw. From their website: The Kangaroo Paw features 144 precisely positioned diamond and tear-drop pillars. More than just making the disc stronger, the pillars provide a greater surface area than traditional straight vane designs. Greater surface area means more effective heat dissipation and cooler running disc rotors. The Kangaroo Paw disc rotors will quickly remove the heat, cool the discs, and return to optimal operating temperatures ready for the next braking application. Cool air flows in from the centre of the disc, while hot air is forced to the outside of the disc - regardless of rotational direction. The pillars provide greater strength across the disc rotor and reduce the tendency for disc distortion. More efficient cooling improves brake pad and disc rotor life, and helps reduce brake fade. Last edited by gsodonis; 09-22-2006 at 05:11 AM. |
Im a nub in this field... so whats makes a rotor 2 pieces, and what are the benefits?
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
If you look at your breaks, you have 2 pads that press onto the rotor (1 on the front 1 on the back). The metal of the rotor inbetween the pads is solid. In a 2 piece rotor, there are 2 separte peices of metal (1 front and 1 back with air channels inbetween them. The advantage is in the air channels. The air passing through them cool the rotors better. By reduceing the temparature of the rotors, you reduce brake fade and also prevent warping.
1 piece vs. 2 piece
A single piece rotor is machined from a single piece of metal.
Pros - least expensive method of manufacturing Cons - If the machining isn't accurate, you can have disk surface run-out relative to the brake hat or the hub mounting surface Cons - heavier than a two piece A two piece rotor has a brake hat that is machined from a seperate piece of material from the rotor. The rotor remains cast, but the hat is usually machined from billet aluminum. The hat is then mounted to the rotor one of two ways, either solid or 'floating'. When solid mounted, the hat is bolted firmly to the rotor at multiple tabs machined in the rotor. When 'floating', rather than bolting the hat firmnly to the rotor, there are pins than locate the rotor radially, but allow for some misalignment axially. Under severe braking, the rotor can distort. By allowing the rotor to float, pad to rotor contact is optimized. Pros - improved braking under severe conditions Pros - the pins act as insulators - heat remains in the rotors and does not transfer to the hat Cons - more expensive to produce Two piece rotors are overkill for the street, but common in racing. They do look awesome however. One piece - both rotors on the left: Two Piece - rotor on the far right: Notice that the hat is gold and the many small silver mounting bolts that hold the hat to the cast rotor. Last edited by gsodonis; 09-22-2006 at 07:31 AM. |
What He (gsodonis) said.
In this link there is more information, and picture 5 is worth a thousand words. http://www.stoptech.com/tech_info/fa...parison.shtml#
thanks for the info!
Ill be finding out today I hope which all rotors they
make for our SVXs We just got a set of their 4000s I think it was for a local 95 Skyline GTR...those are pretty sweet. Hopefully they have the full line for the SVX too
D'oh! This may mean I have no more excuses for not changing my warped rotors.
-Matt |
If I were to choose I would fo with the 4000 6x6 wiper.
thats not a bad idea, maybe everyone post which model and or style you would most be interested in and Ill see what sort of pkg they can put together for us It doesnt have to be immediate, but down the road.
This way If I decide to pre order some stuff, Ill have an idea of what some of you may want so its on the shelf down the road.
I would be in for the DBA Slotted or the 4000 6x6 Wiper depending on the price.
Time to get the car to stop shuttering when I brake. |
