Old 09-19-2006, 05:52 PM
97LSi004's Avatar
97LSi004 97LSi004 is offline
Ignition coil wiring harness
Hi,
I have a bad coil pack on cyl. 6. How do i disconnect the wiring harness without smashing it to bits in frustration? i have tried jamming a screw driver in to release the "tabs" that hold it in all sorts of ways.. if anyone has any hints, it would save me time and frustration.. i was about to cut the wires and splice the new one in..
thanks
-Ryan
My first Subaru, 1997 LSi #004 - SOLD!
Currently driving: 2002 Honda Insight, > 60MPG!
Old 09-19-2006, 06:38 PM
billb billb is offline
Ah yes. I remember the same problem. You're talking about the little connector on the end of the wire. I used a small flat blade screwdriver. It was still tough, but I finally got the connectors apart. Look carefully at your new wire to make sure you're putting the blade in the right spot. I finally got it.
Bill
94 SVX LE 130,000mi
