Old 09-10-2006, 09:23 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
preparing for storage...
ok my list so far includes:
wash it and wax it
clean out the inside
change the oil with a synthetic
cover the car lock it and kiss it good buy for the long minnesota winter that it will be sitting in a garage some where in the big city of minneapolis
i have had some people tell me i should fog the engine... any one with a svx done this before? what elce should i do?
- John
Old 09-10-2006, 10:35 AM
immortal_suby's Avatar
Thread Killah
open box of baking soda in it
battery minder - if you are leaving the battery connected. I have read some problems with the security module failing after leaving the battery disconnected. If you leave it connected without a trickle charger the security system will kill it in a couple weeks.
add a can of fuel stabilizer to the tank
put it up on blocks to protect those 20's
Locker Link
2015 BRZ Limited 6MT
Old 09-10-2006, 11:33 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
As one who grew up with older stored cars and stores his SVX 90% of the time you should never put it on blocks. 1. Can't get it out if you'd need to in a hurry (i.e. fire, etc) 2. Its actually gonna cost ya more in wear to the suspension which is meant to be loaded. Best bet would be to get some doughnuts or spare rims and wheels to keep everything nice. I also coat the rotors lightly with some w-d 40 so they don't rust and cause issues with the abs sensors when you do bring it out. Make sure you clean the undercarrige and let it dry for a day or so before covering. Also, if there is any chance mice might hang out in there stuff your tailpipe and intake with steel wool.
I doubt I'd change it with sythetic fluid at this point. Just put some new oil in it and then add some new oil when you pull it out. Fill up that gas tank and add some stabalizer and drive a good 20 minutes to get it up into the injectors so they don't gum up.
Old 09-10-2006, 08:45 PM
Check the atifreeze as well.
Old 09-14-2006, 07:25 AM
michael's Avatar
michael michael is offline
What Potholes ???
I found this article useful.
http://www.aaroncake.net/rx-7/storage.htm
Old 09-14-2006, 10:08 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Hey man...drive that car....So what if it's winter time...It's crappy in ohio during the winter too...I'd get some winter rims if I were you. And make sure you wash the salt off.
1995 Subaru Svx L / AWD
Old 09-14-2006, 12:38 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Send a message via AIM to SVXer95
Don't put it on blocks. If you don't have an extra set of crappy wheels/tires then you should at least put some extra air pressure in the wheels. Put more in than you usually do. This will help keep those flat spots away. Put in some stabilizer, and leave it there. Starting it up every once in a while will make things worse unless you really get it warm and give it a workout.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
80k miles. MBC + Chips. Relatively Stock
