Old 08-20-2006, 11:02 AM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
FS: 1992 SVX LS-L w/ WRX 5speed on ebay
happy bidding.
this is my vehicle.
http://cgi.ebay.com/ebaymotors/ws/eB...m=110023916180
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 08-20-2006, 11:50 AM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
what are you hoping to get for it? Sorry to see you are letting it go. I know you spent a lot of time on the 5mt.
Old 08-21-2006, 11:51 AM
SomethingElse's Avatar
word words wording
MY SHIFT BOOT LOOKS JUST LIKE THAT UNTILL LAST WEEKEND
Eric
Old 08-21-2006, 01:29 PM
RSVX RSVX is offline
Network Design Administrator
I would guess that he is hoping to get the $2500 buy it now price...
Life is a game. Play to win.
Old 08-21-2006, 01:46 PM
Speedklix's Avatar
Locker Link Solution
Now why would you think that???
Sorry you have to sell your car man! Looks great on the pass side!
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 08-21-2006, 04:02 PM
svxcuseme's Avatar
5 speed 4 sure
Was that there from the start? I obviously missed it. Thanks!
Old 08-21-2006, 07:04 PM
chaswiggins chaswiggins is offline
I must say thats a hell of a deal for that car, even with the body damage.
I would love to see that car get a good home!!!
1992 Subaru SVX
2000 Daewoo Lanos
2001 Parts in my garage.
KYR SCCA member and Rally Driver wannabe.
Old 08-22-2006, 11:29 AM
intellibomb's Avatar
intellibomb intellibomb is offline
i feel your pain with the body damage....
damn the rear quarter panel being one huge unibody piece...
mine has similar damage and it is a B!TCH because you cannot really get it fixed without 500lbs of bond-o
that is otherwise one of the best svxi i have seen.
good luck selling... if i was close enough, i would probably buy it for the 5spd alone....
Old 08-22-2006, 12:39 PM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
Can you get a new quarter panel from another car and swap it?
Old 08-22-2006, 12:50 PM
Earthworm's Avatar
Meow!
You can but there is a LOT of work involved with removing the welded in quarter panel.
Old 08-22-2006, 01:41 PM
davew833 davew833 is offline
Not only is that quarter panel hard to remove, but if the new one's not welded in properly the welds will start to rust through. It's happening to my '92 claret which apparently had the left rear q-panel replaced at some point. the welds rusted through the bondo used to cover the seam.
davew833@yahoo.com
Former 6-time SVX owner
Old 08-22-2006, 02:51 PM
What about all the mechanical things listed? Do all these things NEED to be fixed? If so how much money would it take to do all this. I am asking because it seems to be a good deal, but I don't know much about working on the cars. Seems like they may be expensive repairs if you can't do them yourself.
1. Initially off the line there is clutch chatter but can easily be avoided by babying the clutch engagement. A simple flywheel resurfacing should fix this problem.
2. There is a bearing noise in the driveshaft that is noticeable at highway speeds. I should have swapped in the SVX center bearing. The simple swap should get rid of the noise.
3. The clutch release bearing is making noise; the noise goes away whenever the clutch is pushed in, it is barely audible but I can hear it.
4. The shifter has excess side-to-side movement so it needs new shifter bushings.
5. The car needs new brake pads.
6. The exhaust is also making noise at 3,000-4,000 rpms. The catalytic converter needs to be replaced and is rattling, pre-cats should be used instead.
Old 08-23-2006, 01:02 PM
rmjjensen's Avatar
Thanks for looking guys.
I'm honestly hoping to get whatever I can get within reason. If it sells for $1500 I'd rather start stripping the car and parting it out. Don't want to but I will.
The repairs can be expensive if you don't know what your doing ...the release bearing itself requires pulling the trans. But none of that NEEDS to be replaced (yet) - they're all just annoyances. ...the brakes are one thing though - those DEFINITELY need replacing but that's easy.
Old 08-24-2006, 08:14 AM
rmjjensen's Avatar
hey not bad so far
1,234 unique people have checked it out
and currently
44 people are "watching" it
Old 08-27-2006, 06:00 AM
rmjjensen's Avatar
...bump...
ENDS TODAY AT 9:56 PDT or 12:56 EST
58 people watching it
2177 hits.
