Old 08-16-2006, 12:20 AM
Utah92svx Utah92svx is offline
Send a message via Yahoo to Utah92svx
Car won't start
So as I was driving home the other night my car died on me. It acted like it had ran out of gas. Today I finally had time to get to look at it. It is getting gas (almost full tank) and sounds like it is wanting to start, but just wont. I put a new batery in it cause the one I had was going bad. I am going to check the error codes tomorrow to see what they say. Just wondering if anyone has a sugestion on what the problem could be, or what else I could check. I have only had the car about 3 months, so I dont know alot about it yet but the more I am reading the more I am learning about it.
Thank you in advance.
Old 08-16-2006, 06:20 AM
immortal_suby's Avatar
Thread Killah
did all the dash lights come on when it died?
sounds like the timing belt to me but we will need more info to diagnose.
Locker Link
2015 BRZ Limited 6MT
Old 08-16-2006, 09:52 AM
GARBANZO GARBANZO is offline
Fusable Link
Hi. Have You Checked The Fusable Link, In The Fuse Box Under The Hood? These Can Blow, But Still Look Intact. If You Arent Sure What It Is, It Will Look Like A Loop Of Wire, Where The Fuses Are, And Are Usually Black. Hope This Helps.
Old 08-16-2006, 11:19 AM
Yes all of the lights came on, like they do when the key is turned on. The fusable link is intact I checked fuses and all last night. I do know the cam pulley is in need of replacing.
Old 08-16-2006, 11:27 AM
Earthworm's Avatar
Meow!
If the engine cranks over faster than normal it's the timing belt. When the engine cranks and doesn't start it will usually post a trouble code. Instructions for doing this are on http://svx-iw.com in the SVXipedia.
Old 08-16-2006, 11:40 AM
Does not sound like it is cranking any faster that sounds normal. It sounds like it really wants to start but it just wont. I am checking the codes later on today.
Old 08-16-2006, 12:33 PM
dcarrb dcarrb is offline
I've had a fuel pump fail out of the blue. That's pretty much like running out of gas...
dcb
Old 08-16-2006, 09:43 PM
Today I have replaced the fuel pump, checked for spark, and made sure the injectors were good. I did check the error codes and got a 13 (Cam angle sensor) and 29 (Crank angle sensor 2). Anyone have any other options or know what the codes mean? If possible I would like to try to fix the problem myself, rather than going to the daler and costing a ton of money.
Thank you again
Old 08-16-2006, 10:12 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Your next step should be to check the timing belt.
Remove one of the side belt covers, or at least get it loose so you can pry it open a crack to see the belt.
Old 08-16-2006, 10:52 PM
But if the Timing Belt was off/broke would the engine not crank faster than normal?
Old 08-16-2006, 10:58 PM
Hocrest's Avatar
Unless you've heard it before, or have another SVX to compare it to, thats a pretty hard test to judge.
Before I would throw any parts at it, I would pull a cover.
Old 08-17-2006, 12:05 AM
I will try that tomorrow. Thank you
Old 08-17-2006, 01:29 AM
oab_au oab_au is offline
Thank you again
Look no further, its the crank sensor. Might as well replace all three of them.
One Arm Bloke.
Tell it like it is!
Old 08-17-2006, 10:25 AM
Earthworm's Avatar
Meow!
If the timing belt breaks you still shouldn't get a crank sensor error. You would get a cam sensor error though.
Old 08-17-2006, 12:08 PM
Anyone know where the sensors are located? Are the easy or hard to get to?
I found where they are thank you guys for the help I will keep you posted on the outcome. I hope this is the problem and more dont arise soon. I love the car but is expensive.
