Does the front Sub-Frame move on the frame and effect alignment
Does the front Sub-Frame move on the frame and effect alignment?
I am looking for advice on this subject, let me explain. The front sub-frame is attached to the frame with four bolts. Each of the bolts go through the center of rubber bushings that are part of the sub-frame. The center of the bushings have metal sleeves and the outside of the bushings are pressed into the sub-frame. There is clearance between the inside diameter of the metal sleeve and the bolt outside diameter. This is clearance that might allow the sub-frame to move. This clearance as I remember is about 1/8” total or 1/16” per side. I do not have the exact measurement right now. The sub-frame is held to the frame by the clamping force of the bolts that goes through the bushings. The clamping force prevents the sub-frame from SLIDING on the frame. The clamping force of the bolts applies a friction force to the bushings and has to be higher than the acceleration force of the front wheels and also the braking force and cornering force of the front wheels. IF the clamping/friction force is lower then the tire forces or reduced such as when the sub-frame bushing are covered in oil, then the sub-frame can move when the tire forces are applied. When the clamping force of the bolts is NOT high enough the sub-frame will move relative to the frame during barking, acceleration and cornering. So the question is this: If the sub-frame moves around 1/16” or so will it effect the alignment? If this “movement” is a problem can it be corrected with a metal stainless steel SLEEVE between the clamping bolt and sleeve in the bushing, something to take up the clearance between the bolt and bushing? Is there a similar problem with rear sub-frame? I do not know much about that system of attachment, as I have not it apart. Thanks
May your transmission live forever. SuperbVehicleXtraordinary Proud sponsor of a 1992 SVX. ![]() |
Here is a quote from Harry Newman "newsvx" on the moving subframe issue:
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-08-2006 at 07:32 AM. |
does anybody have a picture of where these bolts are? reading it is one thing but a picture always help out more
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
Here are some pictures of the rear subframe mounts:
http://www.subaru-svx.net/photos/use...toloczko|30914 I don't have any pics of the front subframe mount bolts, but they are pretty easy to spot. Look for the front subframe and look where it attaches to the underside of the car.
that's very helpful. i'm sure i can get a good guess on where the front ones are.
John,
The center tubes of the bushings are serrated on their ends and 'dig' into both the bolt and frame when tightened. Add in the fact that the bushings allow flex to occur, the center tubes don't move - at all. If they did they would quickly chew through the sheet metal 'frame' and you would have a big problem. Like, "Why are my front tires rubbing against my back tires?" So... no, the tubes don't move and allow alignment change but yes, the bushings do. This is all normal and tolerable and won't adversely affect your tire wear.
The rubber washers that sit between the top of the sub-frame and the body are not compressed by the bolts. IF this happens I think the bushings have moved in the sub-frame. I have compared the thickness of new rubber washers to the ones in my SVX and they are the same thickness. These rubber washers keep the sub-frame from boucing up and hitting the frame (body). Heck if the rubber washer is removed, and the sub-frame tightened, there is clearance between the top of the subframe and the frame (body) on my SVX. IS this normal? So Beav, the ends of the tubes for the center bushings in the sub-frame are not serrated on my SVX as far as I can tell, the surfaces look pretty smooth. So IF the subframe can move 1/16" will it mess up the alignment? The only part not connected to the sub-frame is the the top of the strut that goes to the body. Everything else, lower control arm, stabilizer bar, rack N pinion are all connected to the sub-frame.
