Rear transmission seals SVX to Outback
Are the rear seals(driveshaft) different between the SVX 4eat and a 1996 Legacy Outback 2.5 4eat? I noticed mine to be leaking more than it should
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT ![]() |
-did you clean them first?
if yes, did you also grease them? -did you notice a little spring acting like a rubberband inside? are you sure it is the seals and not the side plates?
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
If you're reffering to the extension oilseal, they're the same, but the one that came on the transmission might be damaged. The subaru part # is 806735200 and they run anywhere from $10-15 from dealers.
Cheers |
I looked the parts up at Autozone
