After market front axles????
Does anybody have a source for new/rebuilt front axles?
My shop can only find them through Subaru.....pricey. Thanks, R. Augur |
Autozone, Advance Auto, Pep Boys, etc. Any major auto parts supplier will have them. Probably around $70 for lifetime warranty ones.
http://autozone.com/servlet/UiBroker...%7ENONE%7C%7EV http://www.partsamerica.com/ProductD...pe=945&ptset=A
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by Manarius; 06-03-2006 at 09:09 PM. |
Thanks,
I was under the impression that they would be hard to find......sorry for not doing my own homework |
I have used NAPA before as well. They are easy to get and are less than $100.
Rock Auto is in Madison, WI.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
I and other members here have had great success with replacement axles from
They are done on an exchange basis. They charge you for the axles and a core charge. They ship you the axles, you return your old ones in the same shipping box and they credit you for them. They come with a lifetime warranty. .
Yeah, raxles is a little more expensive, but they use new CV joints and high quality boots.
As with most things, you get what you pay for. The reman units sold by the big parts chains are hit and miss. Usually miss. Good thing is they usually come with a lifetime warranty, bad thing is you may have to replace them a few times before you get a good one.
Raxles are more expensive but again, you get what you pay for. After getting my first Raxle axle a while back I was amazed at the obvious quality difference. I'll never buy a cheap axle again. |
get the raxles or buy ours since my wife smacked her 97 up an hour ago...
Sold-Black 97: They're All We'll Drive-into the side of a Pathfinder that lost it's path! 2004 Stage 3 XT Forester-Soon for sale! 2007 Jag S-type, just 17k on it! Past prides: 1992 black LsL new off the lot. 1992 pearlie for a few months. |
I'm on my fifth Subaru and have used nothing but Brand-X remans from whatever shop was handy (including for the SVX), with no troubles at all.
dcb |
Dan |
1) Bought new; sold @ approx. 212,000 miles 2) Bought new; totaled (rolled and walked away) in mid-40s 3) Bought new; ex-wife traded for Civic Del Sol Si @ 64,000 miles (mid-life crisis) 4) Bought used; sold @ approx. 200,000 miles (wish I'd kept it) 5) Bought used; approaching 139,000 miles All maintained with no-name aftermarket parts. dcb |
