I took a set out of an newer car. Everything bolts right in. Not sure, but I think only the US cars had the auto belts, but all the cars were engineered to mount either system in them.
Here is a list of the stuff you will need to do it right. Seat belts,including the female part that mounts to the seat. trim pieces for above the doors passenger grab handle mount ( different mounting location) Carpet. plastic pieces to cover the hole were the lap belts came out of the console. the rear panels are the same.
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport Last edited by nubs; 11-14-2004 at 05:17 PM. |
Wher did you find the parts
I have called a bunch of places, even in the North West and still haven't found belts from an SVX. I am thinking about getting a generic set of gray ones from a standard Subaru.
Meanwhile... I never use my rear windows so I plugged up the driver's side rear window switch to the seatbelt motor. When I get in I just hit the switch. Kinda goofy but it works. Plus the light doesn't blink. |
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
Your best bet is to find what you need from someone here that is parting out a later model SVX. As for as taking some from another Subaru,you prbably would have a hard time getting them to mount correctly. If they are not mounted using OEM bolts and mounting points you are looking at a safety issue also. Quote:
If that does not concern you, no problem. You could let it go,or patch it with a piece of carpet. The donor car I got the parts from had a nice carpet set in it so I put that in also.
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport Last edited by nubs; 11-15-2004 at 06:25 PM. |
Window switch
Funny thing... I may try to wire an inline switch similar to the window switch to buy some time till I can find a good doner car. It hasn't been too bad just using the rear window button to move the belt. I like having control over its function. No glasses being pulled off or hair being pulled.
both my 94s have the manual normal belts. I hate auto belts because they break and malfunction too much. anyway i think some 94 models and up have the regular belts. good luck finding them if thats what you want.
Tom |
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport |
Help!
Not to beat a dead horse, but...
When I pulled all three plugs to the driver's auto-seatbelt I was still getting the clicking sound! That, and the seatbelt light kept flashing while I was driving with all the belts connected. Does anybody know the difinitive wires to cut, unplug, etc. that will 1.) Keep the seatbelt shoulder attachment in the locked, upper position, providing manual attachment as an option. I believe the safety aspect of the lapbelt is mechanical: does anyone know if the shoulder belt's "reel" is also mechanical in nature? 2). Keep the seatbelt light on the dash off when all the belts are actually attached. 3). Keep the ticker in the trunk off: I have to presume that if the power to the ECU is off there should be no relay?/ECU? ticking? I really appreciate your thoughts: I do want to get this sorted out in the end, but would just like to have a safe way to be able to let my wife use the car until my seatbelt parts ship comes in... I don't want the battery running down, the relay to blow, etc. Cheers! Norm
' 92 SVX @ 185K ' 91 420SEL @ 223K! ' 88 420SEL I. @ 178K (what a buy!) ' 87 F250 @ 180K ' 93 ZX-11D @ 29K ' 93 SC400 @ 93K 2001 Valkyrie Interstate @ 6.6K (Brynhild) Y2K NightHawk 250 @ 1,500 miles ' 88 420SEL II. @ 208K '85 F150 @ 135K |
Sorry all to bump this old thread - but I did so in particular to see if anyone found a fix to "STORMINORMAN" message below. He illustrated a problem that I just experienced with my new (for me) 92 SVX I purchased yesterday. Is there indeed a way to leave the seatbelt in the "locked" position and then use the manual release button to secure the belt? Does this solve the clicking problem? If, worst case scenario, I take the car to the dealer, will they be able to diagose and fix the problem for under $300. Thanks in advance for your help and guidance.
-Craig |
Driver's auto seat belt clicking fix
I know this is not a REAL fix, but just thought i'd thrown my two cts. worth in. my problem is identical to StorminNorman's.
The answer: disconnect the fuse to the warning flasher; this will stop the clicking of the relay. then disconnect the belt from the latch (which should be in the rear of its travel. Buckle up manually! FWIW, |
I (finally) fixed mine with a new (to me) "black box"...
Anybody ever figured out how to fix the relays on the circuit board?
Cheers!
#28
Things are escalating (auto seatbelts)
I'm using SVX Jazz's idea- using the rear window switches to control the seatbelts, I love it. You can find a write up on svx-iw.com
#30
It works; but still, no joy
