after i have installed the ecutune v1.4 i've noticed that the car has this happening when i start the car. the car starts and the rpms goes up and down....giving it a little gas helps out the problem..
i've changed the battery - new battery..interstate..and had the altenator rebuilt just recently. there is a new fuel pump and the fuel filter has been changed as well. it's recently over the last week or two i have the car stall out on me on a cold start....as if there isn't enough gas going into the engine on start up.... starting it again and giving a little gas does the trick. but......to give a better idea....if the car was manual transmission....then i would say that there isn't enough gas going into the engine.... i kind of dont think that it's an electrical problem...which is usually what a tech would attack first (pick on the cheaper route-...well that's what they teach in school apparently)...but then again...that includes sensors too... my guesses would be: 1) fuel pressure regulator 2) spark plugs???? (doubtful on that guess) 3) 02 sensor ????? 6) /////////// i have no clue actually.....?????? that's why = ![]()
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
When is the last time you changed the plugs?
1992 Midnight Black LS-L - Sold 3/3/06 1991 Toyota MR2 - Sold 11/27/07 1992 BMW 325i - Tokicko Suspension |
i got some vacuum hoses replaced today.
but i have to find out. only having the car die out on cold starts... but it did seem better even with the hoses changed. weather is too unconsistent as well here. thanks for the reply
I've had Stage 1v4 for quite a while now without any problems, and its never done anything like that. Don't know what it would be though, but I know it isn't the chip.
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD* My Cardomain page Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX |
steve?
is it on cold starts? or all the time... i didn't have the problem before hand either.....didn't make sense to me... still doesnt....but...i'm losing a lot of confidence in my mechanics.... actually i would rather not have them work on my car anymore....but..it's only convenience....and nothing else... i would work on it myself...but i just dont have the time and a garage . i think it's something to do with the air fuel mixture or spark....(ignition coils?) only thing that makes sense when starting a car.
does anybody actually know the symptoms of dying or dead igntion coils?>?
dying ignition coils would be rough idle, bad acceleration stuff like that. if it dies on cold starts i'd say the temp. sensor, my '95 would run fine but when the temps started dropping into the 40's to 50's it would start rough and die. had to crank it over acouple times before it would stop throwing a tantrum, then when it got into the 30's I killed the battery trying to start the car. finally got a new temp. sensor and my problem is gone. also, stage 1v4 in my ''92 and have never had problems involving the chip.
dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few ![]() ![]() ![]() 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold ![]() 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
![]() It'll happen on random cold starts, usually around every 4th start or so. RPMs will flare up then die completely, CE light comes on. Giving it a little gas makes it start ok.
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
no i have the switched installed....but...i guess i will use it when i am absolutely poor...it would save me some money...since gas is about a dollar a litre here in toronto (for 87 octane)
....knock sensors? well...i'll give the car a check now...i'm going off to work.... i'll reply back later...but i'm not sure how cold it is outside yet. i'll keep whoever is following posted.
nope...the car isn't drastically better....
but i think temperature is a factor... maybe the temp sensor as odepaj said... it's hard to tell.... i think the car wasn't taken care of very well from the last owner.... which is the reason why i have to fix everything.
my car is just like yours steve....
dead starts..gassed the f ![]() no clue MF
i had the fuel filter changed a few months ago....... ...it's really hard to say...it's probably a different thing on both our cars..... it's too bad we dont live close to each other....we can just start ripping the cars apart.... DIY rip your car apart// well...i'll keep working on it... i'll keep posting my progress
