Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 10-16-2005, 05:36 AM
scoobymal's Avatar
scoobymal scoobymal is offline
Smile My new brass radiator/header tank
After all the overheating probs i've had-blocked rad,leaking water pump,dodgy thermostat/cap,the final straw was when the plastic header tank cracked just below the cap.My local radiator specialists were stuck to find a suitable replacement,so they made one from scratch out of brass.Pretty good job considering the work involved,bracketsfor fans etc,for us in the UK the firm is called Serck Intertruck.
pic below.
Old 10-16-2005, 09:30 AM
How much did they charge you to do the work? Looks good.
Old 10-16-2005, 09:48 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Notice the slight angle of the overflow pipe to assure the cap is aligned when closed.
This looks like outstanding "attention to detail" work!!
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 10-16-2005, 09:50 AM
I second Earl's question.... How much?
Robert
Old 10-16-2005, 10:11 AM
Is this just a brass top tank and stick with the pastic bottom?? Looks pretty good
Old 10-16-2005, 02:51 PM
scoobymal's Avatar
Smile
Just back in from work! Price for the new header tank in brass was £52,my contact there said it was a lot of work,what with parts/labour they probably made a loss.That price included pick up/delivery to my uncles garage.I sent a few extra pounds with the delivery driver to cover (drinking expenses) My contact commented on the poor quality plastics that Subaru use for radiators (they are kept quite busy with imprezas/leggys) the bottom of the radiator is still plastic,but seems ok,must be the heat that destroys them.With 150,000 miles on lets hope nothing else goes wrong (still on original gearbox with no history of faults)
Mal
Old 10-17-2005, 12:01 PM
Earthworm's Avatar
Meow!
You should check to see if he would be interested in making up for his losses and getting a batch of them made for us.
Does anyone know if brass and aluminium react strangely when mated against each other?
