Old 07-28-2005, 10:57 AM
pnyklr
How to fix antenna
I've got two.. mine doesnt do anything, its got juice though we tested it with a test light and the other the black piece is broken on the shaft.. how do I change it??
Old 07-28-2005, 11:00 AM
pnyklr
Oh the other antenna works perfect except for that black piece being broken
Old 07-28-2005, 12:54 PM
dcarrb dcarrb is offline
Do a search. Somebody had a pretty decent "how-to" with photos, but oddly enough, it's not in the How-To documents. I can tell you that, if the plastic take-up leader is broken, you'll need to pull the drive assembly and remove the broken end from the spool housing.
dcb
Old 07-28-2005, 01:09 PM
Earthworm's Avatar
Meow!
You can check the SVXipedia on http://svx-iw.com/
Old 07-28-2005, 09:14 PM
pnyklr
I checked did a search using antenna ... no dice unless I am missing something... anyone have any ideas ?
Old 07-29-2005, 12:24 AM
I have it, but not on this computer. I will see what I can do for you.
Old 07-29-2005, 06:16 AM
pnyklr
Thanks I dont want to take it apart unless I know what the hell I am doing
Old 07-29-2005, 10:45 AM
I will check, but I think I have the write up on the other computer at work. I will check and if so, I will put it in the How-To Docs and post again here to let you know.
Old 07-29-2005, 10:53 AM
pnyklr
Cool thanks
Old 07-29-2005, 01:35 PM
I just got the How-To put into the locker. The pictures are small and grainy, but I will work on getting the pictures replaced with better ones. It is the best that I can do right now. Lwin did this write up with the pictures, but I don't have larger pictures to put into the file. I will try to get them from him or take new ones myself.
Old 07-29-2005, 01:37 PM
Here is the link to the How-To.
Old 07-29-2005, 02:45 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Actually, that's my how-to. I'll try and dig up the photos, I'm sure I have copies of them somewhere.
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 07-29-2005, 03:22 PM
Earthworm's Avatar
Meow!
Hey Doug, you have a few howtos right? You should submit them all to the SVXipedia.
Old 07-29-2005, 03:37 PM
mohrds's Avatar
Its been on my mind for a few years, I just haven't sat down and looked for them.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 07-29-2005, 04:08 PM
Sorry Doug. Lwin had it posted I guess. If I use the larger pics, they will not be as fuzzy.
