Old 05-12-2005, 11:40 PM
92AWDSVX
DAMN WHEEL BEARINGS...i think
Ok i was making a turn goin about 15-20 and the rear end slid out then cought kinda hard. And now when i drive it makes an grinding noise... Like on off... like GRIND GRIND GRIND... not like grinnddddddd constant, and the faster i go the faster the grinding gets and louder it gets, WHAT COULD IT BE!? CoULD IT BE A WHEEL BEARING AGAIN! IF IT IS THESE CARS GO THROUGH THEM LIKE CRAZY!!!
Old 05-12-2005, 11:45 PM
Rd96SVX's Avatar
Rd96SVX Rd96SVX is offline
antidisestablishmentarian
Send a message via AIM to Rd96SVX Send a message via MSN to Rd96SVX
hmm
How in the samhell did you get the rear end to slide out going 15-20, I can't seem to get mine out when I'm trying to, let alone just going 15-20. Just curious....
-Alex
1996 Brilliant Red LSi "Allie"
+226k mi.
25,000 lb GVW Trans-Cooler
Wet-sanded "cleared" Headlights
Charcoal 22% Tint
Removed intake resonator
'95 Probe GT Wheels
'97 grille
"New Addition" 1992 Teal LS-L
+156k mi.
Status... Reconditioning
Old 05-12-2005, 11:48 PM
92AWDSVX
I got the fuse in, so its RWD, when the fuse is out it seems to shake a little bit, like vibrate kinda, i dont like that... so i keep it in...
Old 05-12-2005, 11:52 PM
Rd96SVX's Avatar
that splains it, thanks I was really confused for a moment.. as for what it could be other than a bearing, if it really did catch as hard as you say, it could be a caliper/pad/heatshield issue, just tossing out ideas,I haven't heard it or i might have a better idea
-Alex
+226k mi.
Charcoal 22% Tint
'95 Probe GT Wheels
'97 grille
+156k mi.
Old 05-13-2005, 12:03 AM
SubaSteevo's Avatar
No longer blue member
The fuse makes the car FWD, not RWD (unless you've done something I don't know about). Using the FWD fuse is for testing only, because it does bad things to the drivetrain. You very well could have blown your rear differential.
-Steve
01' MSM Lexus IS300
Old 05-13-2005, 06:37 AM
92AWDSVX
Well i have the fuse in and it is rear, lol cuz the rear end slid haha, so i duno, but the fuse has been in forever and hasnt dont anything, its been in since i bought the car
Old 05-13-2005, 07:05 AM
dcarrb dcarrb is offline
As Steve said, the car CANNOT be made rear-wheel drive; not without major mechanical modifications, anyway. So, you had a vibration when the fuse was out, and now you've picked-up a grinding sound. What you have is drivetrain problem that'll soon leave you walking if you don't tend to it now.
And yes, that noise could be wheel bearings, if they weren't installed and/or greased properly the last time around.
dcb
