Thread Tools | Display Modes |
attn: ECU OBD Hackers - emulate the select monitor using windows and RS232
I want to get some information out of the ECU on the fly. I figure I have a computer in the car already so I'm more than half way there. I know standard OBDI / II cars communicate through serial data, and I'm going to go ahead and assume that the select monitor does the same.
So far I've accumulated the following information regarding a 92 Subaru SVX: There's 3 access ports coming off of the ECU as follows: The Diagnosis Connector ..Black w/ Blue - Ground ..Blue w/ White - Read Memory Connector ..Orange - Test Mode Connector The Check Connector ..Orange - Test Mode Connector ..Brown w/ White - Select Monitor (Tx) ..Light Green w/ Red - Select Monitor (Rx) Select Monitor Connector ..Brown w/ Red - +12V Ign ..Brown w/ White - Select Monitor (Tx) ..Light Green w/ Red - Select Monitor (Rx) ..Blue w/ Yellow - Trouble Code Output ..Black w/ Red - Ground So I'm planning on using this IC: http://www.elmelectronics.com/DSheets/ELM323DS.pdf to communicate with the select monitor and the RS232 port on the car computer. I'm guessing if I just use the select monitor Tx and Rx lines this should work perfectly fine. Does anything know if there's anything special regarding the select monitor? Hopefully this goes nice and smooth. Do I even need the ELM IC chip? I need to know if the select monitor uses the ISO9141 or ISO14230 protocols
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing ![]() 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
This is an excellent idea! i would love to do it. PM me if you get it working i will do soem looking around and see if i can find any info on it.
www.svxtasy.com |
The one problem that usually comes into play is that the ECU doesn't have an easily defined "language". This may not be the case with the SVX, however with DSMs, its taken quite a bit of "hacking" to figure out which sections of code do what. if it follows one of the protocols though, that would be awesome.
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
