Dyno Runs at Altered Atmosphere 12-15-04
Did two runs on the awd dynojet dyno at Altered Atmosphere in Gaithersburg, MD.
My engine mods as listed in my sig are: STI panel filter, removal of my exhaust resonator and modification of my intake resonator (4.11 gears help bring 16% more torque to the wheels, but the dyno cancels out their benefit). Temp was 38* outside and probably around 45* in the area where my car was dyno'd. Ran on 93 pump gas from Shell and both my alternator/PS and A/C belts were hooked up. Results are shown below: (Peak values) Ist run: 164.5 hp & 172.1 ft-lbs 2nd run: 165.1hp & 173.4 ft-lbs Graph of my second run is shown below: ![]() Based on a 30% loss in the drivetrain, this puts my flywheel power at around 236hp. All of this gain cannot be attributed to the high flow panel filter, but my numbers definitely show that removing the stock exhaust resonator doesn't harm top-end power or torque... I'll finish up with a pic of my car on the rollers... ![]() -Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 12-15-2004 at 09:42 PM. |
Chike,
Do you have baseline runs before you did any modifications? If not, these runs don't really tell if your mods did anything. I'm not trying to say that they didn't, nor am I trying to discourage, just that you are assuming drivetrain loss and do not really know what the power at the crank is. BTW: How did Bill do?
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock ![]() ![]() |
Based on other people who have dyno'd their SVXs in the past, a 30% drivetrain loss is a fair estimate, as our cars are both awd and have an auto trans. I have no baseline runs, as these runs were supposed to be my baseline (only real power mod is the STI panel filter). SVXRide will post his results at a later date. -Chike
Hey Porter...
any idea how close my results on the dynojet are to a stock '02/'03 WRX w/ 4EAT running on a similar machine?
-Chike
Re: Hey Porter...
Alan 1987 928 S4 (Black) SOLD! ![]() 1997 SVX LSi (Ebony) SOLD! ![]() 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! ![]() 1987 928 S4 (Black) SOLD! ![]() 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
Re: Re: Hey Porter...
![]() The 4.11 gears and 3430lb weight (w/o driver) of my SVX will keep me in the running. The only magazine to have tested a 4EAT WRX was Road & Track back in '02. They got 15.2 @ 92mph. I was practically at that time last time last season and I'll be adding a few more 'goodies' over the Winter... ![]() -Chike
And the 3.3 should have the jump off the line due to the better bottom end torque...
hey chike what kind of mods are you preparing for the winter?
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd ![]() 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
Nice clean runs Chike. Good point about the removal of the exhaust resonator not having any effect on torque/HP. BTW, you might want to mention that you had disconnected the battery just before the runs.
Re: Re: Re: Hey Porter...
[/COLOR][/COLOR]-Scott My Locker 2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14 2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14 1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65 1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07 1994 Pearl White LSi Bought: 2001? Sold: 2004? |
As Bill was helping me install a -ve grounding wire, on a grounding kit, I had to disconnect my battery for about 20 minutes before my run. This seems to have hurt my results slightly as the ECU on my first run had an afr of 14.1 when I hit my peak 164.5hp. On the second run, my ECU richened the afr to 13.6 and my max power increased to 165.1 (tq also increased by 1 ft-lb). When Bill made his dyno runs during the summer, his stock ECU richened the afr to 13.4 when he made max hp. If I had done a 3rd or 4th dyno run and my ECU had richened my afr to 13.4, my peak power may have increased by another 0.5-1hp or so... -Chike
![]() My 1/4 mile runs and now dyno results prove that a properly modded SVX can be every bit as fast as newer, high performance Subarus on the market (with an auto trans). Quote:
-Chike
awsome news Chike. I ams till waiting for you to set up a date when you will come to Atco so we can throw down
Hey Tom ya bringing the 5 speed to the meet?
Seems like my 165.1hp at the wheels can be a combination of 2-3 hp from my STI filter and 'production tolerances' giving me an SVX with a strong engine. -Chike P.S. I'm not too sure about Atco right now. I'm trying to talk my wife into going to Reading in April. If that works out, and there's drag racing on Sunday, we can have at it there! ![]()
