Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 09-08-2004, 06:21 PM
Jnthn_Sctt Jnthn_Sctt is offline
Thumbs up
Originally posted by longassname
Here are a couple more pics of the tires up front. I'm charging up the flash now to try and get the requested rear pic to show the width of the tires instead of just shadow.
Michael,
Sharp looking tires. Look a lot like mine!! LOL First time I've used Pirelli instead of Bridgestones, they ride very nicely, Thanks again.
Nice job on the Stage 1 chip too!!
Would the 255/35's work with an 18" X 8" rim with 40MM offset? Are we any closer to working out the math on what will and won't fit?
Thanks again,
Jonathan
Old 09-08-2004, 08:19 PM
longassname's Avatar
Just some dude.
Significant Technical Input
Originally posted by Jnthn_Sctt
Michael,
Thanks again,
Jonathan
Glad you are happy with them. (for those of you wondering Jon is now the owner of the 225's I replaced with these 255's) Nope, I think if you mounted 255's on your wheels that the back tires would rub on the outside.
Old 09-08-2004, 09:03 PM
That's what I was afraid of. But in light of this being my daily driver and not a racer, I don't know that I would need steamrollers like that anyway.
They do look sharp though.
Jonathan
Old 09-08-2004, 09:20 PM
Just some dude.
Jonathan
Bigger tires are more weight and svx's already stop well so if you don't have a stage II and need traction you are right that you are better off with the 225's.
Old 10-01-2004, 12:17 AM
svxboy svxboy is offline
Send a message via Yahoo to svxboy
255/35R18's
Doesn't that size have a slightly larger overall diameter than stock? I think the 245/35R18 are almost identical to stock. Is your speedo off?
Greg
92 Teal SVX LS, Superwhite headlamps and front turn signals, Premier DEX-P1R Deck, A/D/S P850 and Earthquake 200DHC amps, PG Bass Cube, 3-10 in. Diamond Audio subs, A/D/S 346is front components, and Vifa rear 6x9's. B&M tranny cooler and temp. gauge. Flowmaster custom dual exhaust, Tenzo-R conical intake filter, JC Sports torque chip, and a Mid-Height wing for an Integra that fits perfectly and stands 6.5 in. tall. ART front and rear cryo/slotted rotors, SS brake lines and EBC "Green Stuff" pads. My email address= fastestsvx@yahoo.com
Old 10-01-2004, 01:05 AM
Just some dude.
Re: 255/35R18's
Greg
No, actually the 255 35 18's are identical to stock
Old 10-01-2004, 12:45 PM
I guess it depends on how you look at it. Using the equation to calculate overall tire diameter,
[(width X aspect ratio)X2] / 25.4 + Rim size
I come up with...
factory size P225/50R16=24.858"
P245/35R18=24.751"
P255/35R18=25.0275
So, I guess each is close, one is slightly larger, one is slightly smaller. It may affect the speedo and final drive slightly.
Greg
Old 10-01-2004, 01:14 PM
Just some dude.
tires vary. you have to look up the actual rpms for each tire.
Old 10-01-2004, 05:15 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Here is an Offset calculater that someone just posted on USMB...
http://toy4two.home.mindspring.com/offset.html
It won't answer all your questions, but can't hurt either...
Old 10-01-2004, 08:05 PM
Wiz Wiz is offline
Send a message via ICQ to Wiz Send a message via AIM to Wiz Send a message via Yahoo to Wiz
Common, someone. Where are the Stage II time slips at?
Green 1994 SVX LSi - Totaled by a plow. RIP
Bordeaux Pearl 1994 SVX LSi - 182k
Old 10-01-2004, 08:09 PM
Just some dude.
Unfortunately ECUtune Stage II was removed as part of the Stage III set up process so we won't be getting 1/4 mile times for stage two from our own test vehicle anytime soon. Will stage III times be good?
Old 10-01-2004, 08:12 PM
Subafreak's Avatar
Superbeast
Working on it!
Old 10-01-2004, 08:14 PM
Subafreak's Avatar
Superbeast
BTW: Mike I was serious about the wheels. What are they, where can I get them and how much is it gonna cost me to rip off your idea?
Old 10-01-2004, 08:27 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Correct. Different brands and types of tires having different rolling circumferences. For example, in the stock size 16" 225/50 series tires, an all season M+S tire with a treadwear rating of 400 will have deeper tread (and thus a greater rolling circumference) than a summer only high performance tire with a 160 treadwear rating...
Compare the specs on similarly sized tires at the Tirerack to see what Longassname is getting at.
-Chike
2006 Steel Gray WRX TR (sold)
Old 10-01-2004, 11:57 PM
Just some dude.
Like Mike wanna be like Mike.
Mine are ROH Drift R's. ROH makes other wheels in the same width and offset. In fact you can get 17's in the same width and offset though I wouldn't get 17" drift r's...the big lips make the center sections look smaller so larger wheels look better. You can get the roh fury or the roh rt in 17's in the shadow chrome for a lot less than the drift r's.
