Old 09-14-2004, 12:43 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Re: Garage queen??
Originally posted by svxistentialist
Not as laid back as you used to be, eh Andy??
Costing £1200, it stays inside in bad weather. That means the Lee Cougan has had plenty of use this summer.
I am booked in to do a 60 mile charity ride next month, so it will have to get wet a few times in training. I have just fitted clipless pedals so I will need to be happy with them before riding with about 1000 others.
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 09-14-2004, 01:58 AM
OK I understand.
Is the Lee Coogan mid engined and rear wheel drive?
Old 09-14-2004, 03:15 AM
Andy's Avatar
OK I understand.
That's the one Joe. Unfortunately the engine is in rather poor condition, with worn pistons, a leaking head gasket and a limp big end.
Andy
Old 09-14-2004, 03:59 AM
Sounds like it needs a service badly.
Try a few pints of antifreeze or equivalent down the throttle body, and regular application of friction modifiers on the con rod. That'll help the big end.
How's the XT going? What's a typical mpg for it? My brother is awaiting a Forester Turbo from Japan, 98 or 99 model I think.
Old 09-16-2004, 02:32 PM
Andy's Avatar
Realy nice, very few bad points. Much better average economy than the SVX, I recon that 'Er Indoors' gets about 35mpg and I get about 10.
Sounds like your brother is getting an S-Turbo. A more primative beast but probably well tuned if it is a Jap import.
The only disappointment is that Prodrive are not doing an upgrade for my '04 yet. I could do with a little more power.
Andy
Old 09-16-2004, 02:42 PM
Royal Tiger's Avatar
Certified Porschephile
Why does everyone want to race an SVX? It's a GT. Tell roto-loser to go find a rustang to pick on; until his gaskets blow. The rotory is far more unreliable then any other motor I know of. I have seen some nice tricked out RX-7's in SCC magazine, but they dance a fine line with fuel/air mix and resulting detonation.
Old 09-16-2004, 05:45 PM
Originally posted by Subafreak
Or stage two.
Hell with an abusive enough launch, I can spin 4 tires.
I didn't want to mention this earlier, but now seems like a good time.
I can easily squeal my front tires, and roast them for a good 30ft, and one day, I decided to see what I could really do.
I chirped that sucker on a slight incline, but instead of holding it or letting off, I opened up the throttle and just tore up road until I hit second gear (or the awd kicked in, I don't really know) and got launched like a rocket.
Never did the rear tires squeal.
You have to consider if your torque distribution is working properly, and considering the whp of these things, a slightly modded X will only put 45h per wheel to the ground in low traction conditions.
If you are spinning all four, you have to be pushing a lot of power, or heck, abusing the hell out of a 5-speed.
Old 09-16-2004, 07:59 PM
Subafreak's Avatar
Superbeast
^ That one
