Old 08-30-2004, 04:52 PM
92black svx
brakes
Loseing brake flood and cant find where. If i push hard on the peddle at a stop it slowly goes to the floor. Does that mean the mastercylinder is going bad?
Old 08-30-2004, 05:13 PM
I've never seen a Subaru master cylinder, go bad, but if you remove the M/S, and reach into the brake booster and you get brake fluid on your finger/probe, then yes, it's leaking into the booster.
Old 09-01-2004, 11:41 AM
Earthworm's Avatar
Meow!
No puddles anywhere?
Old 09-01-2004, 11:58 AM
dcarrb dcarrb is offline
If you lose the pedal at a stop with the brake reservoir full of fluid, then yes, the master cylinder is probably worn to the point of letting fluid seep past the piston.
dcb
Old 09-01-2004, 03:31 PM
92black svx
thank u for the info. earthworm i have peddle when stopping just not when im sitting at a red light it will slowly go to the floor if i put presure onit
Old 09-01-2004, 04:49 PM
SubaSteevo's Avatar
No longer blue member
I've got a master cylinder you can have for $25 if you need it, located about a half hour from Reading. PM me if you want it.
-Steve
01' MSM Lexus IS300
