heat shield removal
Ive removed the heat shield up to the ones around the O2 sensors. Is it ok to remove these too? There is some type of boot right above them and i dont want to melt it, but i have got to get rid of this rattle before i go insane. I keep having exhaust work done but it rattles so bad i cant even here the note anymore.
Is it actually possible for that shield to rattle that bad or could it be something else, the entire exhaust is redone fromt that point back. Flowmaster. no resonators or cats. Last edited by mranderson; 07-14-2004 at 03:24 PM. |
There's only one resonator in the stock exhaust system. The other three items in front of it are cats.
im a freakin idiot, i meant heat shields...............AAAAAAHHHHHHH
i am hurt by my on stupidity.... the title of the thread should be heat shield removal......dumb dumb dumb hey look at that i can change the title, so it says the right thing now Last edited by mranderson; 07-14-2004 at 03:23 PM. |
Got 'resonance' on the brain!
![]() You can remove the heat shields, but I know for a fact that the wire to the O2 sensor on the secondary cat runs along the outside of a heat shield for about 2' before entering some socket. If you remove the shields, be sure that you secure all loose wires away from the exhaust pipes with some type of durable fastner. -Chike
so i dont have to worry about that rubber boot melting....just had to replace two tires and money is now very low....
By 'rubber boot' do you mean the exhaust hangers that are connected to the frame via a rubber bushing?
I seriously doubt it'll melt, but high temps over time causes rubber to become stiff and cracked. -Chike Quote:
Re: heat shield removal
Anyway, the rattle of a resonator sounds like heat shields... or "bees in a coffee can" would be more accurate. The difference in sound is minimal, and I've noticed no difference in performance. As far as the shields over the cats... I'd leave them there myself. You could PM Halistan or check his locker... he has a complete custom exhaust on his 93 which sounds awesome... but he kept the heat shields up front. |
WHAT EVER YOU DO DONT DAMAGE THE EXAUST HANGERS.!!! 15 a peace for the 2 point dimond shaped and the v shaped 3 point no longer EXIST. i just tried to order the latter of the two from the dealer and he said "no wharehouse in america has them"
I just had my Resonator replaced by Midas yesterday. I had removed 2 pieces of heat shield previously over a 2 year period which worked but the noise came back after about 1 yr. each time.
After reading some posts here I had it replaced. I want to thank you for the the info. because yes, it was the resonator this time and the SVX is silent now. ![]()
RGG |
You should have let me know. My resonator was still quiet when I removed it in place of the Stebro. I could have gave you a good deal on it.
