#376
The SVreX is a '92 LS-L. Before any changes were made we weighed it on electronic race style corner scales. It was 3566 lbs. with no driver and a full tank of gas.
'92 LS-not-so-L: the "SVreX"- Saved from a crusher, an SVX racer built by home schooled students for less than $2000 (including purchase price). 13.8 second 1/4 mile. Autocrossing monster!! '92 LS-L Claret: '01 RS 4:11 5-speed, Exedy organic, lightened flywheel, and Koni/ GC |
#377
Ya I don't even remember where I got that # from anymore. 3700 is incorrect. It's 3580. my bad
#378
so is everything going to be a package deal for stage 2 other than the plugs? or are we goin to have to buy some stuff like the wamer?
#379
the fwd final drive is 3.70 the awd is 3.56 or whatever.
#380
Ok we definitely need to stop throwing #'s around here..now I'm even making mistakes. I'm pround mine wasn't the most egregious though
#381
Plugs and bottle warmers aren't included but I can sell them too if you like. |
#382
i think it would be a good idea to include the plugs, so no one accidentally(Not knowing what they are doing) gets tyhe wrong ones. Just a suggestion
#383
i have been discussing the syage 2 kit wiht many people and they are impressed with your work. Everyone i speak to seems to worry about the affects this will have on the motor. I am beginning to become quite curious myself. Is this kit completely safe when installed and used properly, or are we looking at something that will eventually lead up to major engine failure?? Just want to know for safety sake
#385
*claps* Good speech for the uninformed. (like myself)
-Craig Lowthorp, Flagstaff AZ '92 LS-L, Black on White, 136k SOLD '92 LS-L, Black on Silver, 120k SOLD '01 Legacy Outback, White, |
#387
Also a good speech for basically agreeing with what I said about JSVXstyle. >wink<
#388
#389
As far as what who may have run in the quarter mile I don't know. I'm not very comfortable with all the unverified #'s being thrown around. I've gone to great lengths to document this project for everyone's benefit and understanding. The posting of the gtech calculations made in our first trial run was part of that documentation--done only to help keep everyone informed of the process we are going through. The same goes for the #'s I'll post from the next run--they are being posted to help illustrate the process and one of the sources of information I am using to do my initial tuning. I hope my sharing those inaccurate #'s doesn't continue to encourage others to post their inaccurate #'s for comparison. Now I'm not going to sit here and try to rule judgement on who's #'s are accurate, who's are innacurate, and who's are outright lies. Those arguements have filled plenty of other threads and have no appropriateness here. I would ask that everyone try to resist throwing them around from now on. Ok, the above was about the general state of the thread recently. Now in reply to your post in particular, mbtoloczko. Part of the problem with using #'s as self evident of something is that they aren't self evident of any one particular idea. I'm not sure what your main idea was. We're you saying that you believe elninoalex's car was generating more horsepower than we did on our first test run or just complaining about the use of the phrase "real horsepower". If you were proposing that elninoalex's motor was generating more horespower than we did in our first test run I would have to dissagree based on your description of his setup but either way it doesn't effect the points I was making in my reply to tomssvx. If you found my wording to be discounting other peoples efforts and result...my appologies. |
#390
I seriously doubt you're even close to the cylinder pressure limit of an SVX motor yet. I expect the 400hp level to be obtainable before cylinder pressure becomes a concern. As you stated before, detonation is the enemy, not cylinder pressure.
All you need now is boooost. |
