Go Back   The Subaru SVX World Network > SVX Main Forums > Technical Q & A > Chris's SVX Shop
Old 11-14-2001, 08:18 AM
svxter's Avatar
svxter svxter is offline
This account is scheduled to be deleted for inactivity
Send a message via Yahoo to svxter
A different front end noise
Since all the talk about clunking noises from the front end at low speeds......
What about a grinding or scraping sound? I've noticed that while making low speed turns. It seems to be coming from the front. It is rhythmic, as if the something is making contact as the wheel(s) rotate(s). It sounds like two metallic object being rubbed against each other; definitely not a clanking sound, no particular vibration. Suggestions?
bill
Green 95 SVX - Cleo
Green 97 Outback - Maxine
Red F-150 Extended Cab Long Bed - Big Boy
Even the best monkey sometimes drops his banana.
Old 11-14-2001, 08:29 AM
cocacola08's Avatar
cocacola08 cocacola08 is offline
Send a message via ICQ to cocacola08 Send a message via AIM to cocacola08 Send a message via Yahoo to cocacola08
Have your brakes changes recently or tires rotated/changed?
Maybe not mounted back on properly, causing a little latteral travel, or the pads might not be on right.
Kev
kevin.m.sheets@verizon.net
Old 11-14-2001, 08:30 AM
cocacola08's Avatar
Since it's not constant it could be a warped rotor.
Kev
Old 11-14-2001, 03:39 PM
Lowered SVX
hey coke.....
not a bad diagnosis at all. i am no expert but that is exactly where i would start. it is amazing how precise the mechanics of this car must be in order for it to operate properly. i think my brakes also have a little play. have someone check the shims. perhaps they are not properly placed and it is allowing some travel in your brakes. i sometimes get a pop from the left front and i think that is what it is from.
"Too much fun to drive!"
Old 11-14-2001, 07:33 PM
svxter's Avatar
A distinct possiblity. I plan to get them checked out next week, when I have some time.
bill
Green 95 SVX - Cleo
Old 11-14-2001, 08:30 PM
Invisible avatar
Thumbs up
Bill - Since you have the advantage of dealing with Duff Subaru, the results of any diagnosics & replacement of any parts will be MOST appreciated.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 11-15-2001, 09:50 AM
cocacola08's Avatar
Re: hey coke.....
I have that "pop" as well I swear its the shims, but I taken them off, put em back on, over and over, I just think Bendix brakes for the SVX aren't an actual factory match.
Kev
Old 11-15-2001, 12:03 PM
Lowered SVX
the same may hold true for the......
aftermarket carbon fiber pads i currently have installed. i will switch to the kevlar pads soon, hopefully there will be a difference.
[IMG] code is Off
