Old 03-09-2004, 02:14 PM
MikeInd
Glass Headlight Assy
Do ther cars over there have Glass or plstic headlight assemblies?
Thanks
Old 03-09-2004, 02:33 PM
Jamsvx's Avatar
Jamsvx Jamsvx is offline
Send a message via ICQ to Jamsvx Send a message via Yahoo to Jamsvx
Glass, but they are angled for cars that drive on the left hand side of the road...they will blind oncoming drivers if you put them in a LHD car/LHD system (like US) apparently
1992 charcoal grey SVX:
27 August 2002 to 27 January 2004 - she will be missed
Was back in Sydney for a while but not hot enough so now in Dubai! Has it been that long since I owned SVX-33H!
Old 03-09-2004, 02:38 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
The Headlight assemblies are the same. There are internal adjusters (you have to remove the lens to get to them) with alignment marks that designate DOT, EUR, or JPN. The German lights have the mounting inside for the fog lamp and adjuster since they also share the same housing with the rest of the world.
The glass/plastic lens does direct peripheral light, but the main focus is controlled by the internal settings.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 03-11-2004, 05:35 AM
Muchas interessanto
That's interesting Doug.
The main beam is the one with the fresnel cuts in the glass/plastic for spreading the beam. When main beam is switched off, dip beam is the hemispherical polycarbonate lens, and it shines through practically plain glass/plastic. So there will be precious little of the dipped beam throwing high to the left [over here] or high to the right [Europe or US]
What does DOT designate? Is it the UK Dept of Transport, and would that be the setting for these parts?
Old 03-11-2004, 07:10 AM
mohrds's Avatar
Re: Muchas interessanto
DOT is Department Of Transportation. They set U.S. automotive standards, they do not enforce or approve individual products.
The DOT and E-code have enough similarities that with minor adjustment the lights can be made to fit into either specification.
This is an example of the beam patterns. If you rotate either one, you will see how it can be set for the other specification.
There are in fact some newer vehicles that comply to both DOT and E-code simultaneously. They barely comply with either, but enough to meet the minimum requirements of each. The pattern looks very similar to a smiley face
Hope this helps.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 03-11-2004, 08:35 AM
Thumbs up
Yes,
That's perfect.
Thanks
