Old 08-02-2003, 10:18 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Hub Rings info w/ Pics
For anyone buying aftermarket rims, make sure they offer
you Hubrings, one for each wheel.
The make the rim fit snug against the factory hubcenter.
Pic one: the actual ring...
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 08-02-2003, 10:19 PM
step 2
this is usually what the back of the new rim '
looks like.....
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 08-02-2003, 10:20 PM
step 3
Pop the ring in the back of the rim
(it goes on only one way...)
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 08-02-2003, 10:21 PM
OR
you can put the ring directly on the Hub like this....
pic one......
This is before.....
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 08-02-2003, 10:22 PM
Installed
this is what it looks like installed on the Hub....
Bolt on your wheel, and your done.....
Mostly youll want these to prevent unwanted
vibration transmitted from the wheels thru the
cars suspension and chassis.....
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 08-03-2003, 05:33 AM
lee lee is offline
thanks Dayle
Old 08-03-2003, 08:38 AM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
do they fit all wheels.
I don't think I have them on my rims
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 08-03-2003, 10:02 AM
Do all aftermarket rims need them?
Old 08-03-2003, 10:16 AM
immortal_suby's Avatar
Thread Killah
Aftermarket rims that do not have the exact centerbore as the svx rim need them to properly center the tire on the hub. They are made specifically to fit the inside of the aftermarket rim and the hub on the car.
Locker Link
2015 BRZ Limited 6MT
Old 08-03-2003, 11:30 AM
its like this
90% of the rims on the market now a days wont come
hubcentric specific for your car..
for example, its much easier to make the centerhole
in the New wheel larger then what all cars need, and then offer hubcenter rings specific for your vehicle
This way they get have their rims properly fit just about any
application.
There are only about 8 different size center bores used
on most cars out there, luckily the SVX is a 56.1 bore and thats the same as alot of Nissans and other cars on the market.
If you dont have the rings, I suggest contacting
the place you bought the rims from and see if they have
them for you. If not, have them contact the manufacturer
of the rims and for about $10 or less they will usually send you a set of 4.
Keep in mind, all centerbores of the Rims can also be different, so its important your center ring fits tightly in the Rim just like it will on the hub. Just about all wheel manufactures out there offer these rings, so check it out.
Sometimes the rings are plastic, some more hi tech companys make their rings out of aluminum.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 08-03-2003, 11:33 AM
wouldnt say any car Need them, but they make them for a reason, and since the cost is so cheap and they are readily
available, I suggest getting some if you dont have them
and you have any vibration problems at any speed.....
Some people will think its wheel balancing causing the problem when it could just be solved by a set of rings.....
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 08-03-2003, 12:39 PM
AFBeefcake's Avatar
Subaru Swapper
well I got focal F-5 rims do you know what size rings I need?
2005 Legacy GT
Old 08-03-2003, 01:02 PM
depends on the rim
They are sized by the inner and outter diameter....
Depends on the size of the hole in the rim.....not sure on
Focals.
The inner diameter has to be 56.1 mm
not sure what Focals size Focals use for the outter
diameter.
If you contact a Focal dealer in your area, they should
be able to tell you.......
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 08-03-2003, 02:02 PM
Noir's Avatar
Noir Noir is offline
re: thanks
thanks dayle
