Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 11-14-2002, 11:13 AM
tranny cooler/ext. filter temp helper
a while back someone posted regarding putting a heat shield on an aftermarket external filter, because it could be getting ambient heat from the engine. as a temporary experiment, i put a few strips of adhesive insulating tape (with aluminum backing, about 3" wide) around the metal filter/mount and temp sensor. i gave the car a SERIOUS workout yesterday running errands (about 50degF outside). went up many STEEP and LONG hills and much stop and go traffic in the process. the highest reading i got was 177degF for a few seconds. before, i would have easily been in the 190's or even slightly above 200. when it starts to get warm again, i'll make a more permanent heatshield. this really made a noticeable improvement on my PermaCool filter, which i have located under the battery.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD!
2005 Forester XT Premium (Crystal Gray Metallic) SOLD!
2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+]
2015 Outlander Sport 2.4GT AWD (Mercury Gray)
2013 G37xS (Obsidian Black)
Old 11-14-2002, 11:50 AM
mattski mattski is offline
Re: tranny cooler/ext. filter temp helper
Landshark, I purchased the same filter but have not yet installed it. When you say "under the battery", do you mean in the wheel well literally under the battery or on the wall to the side and under the battery? Also, did you manage to install it vertically or horizontally?
Thanks,
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 11-14-2002, 11:58 AM
Re: Re: tranny cooler/ext. filter temp helper
Thanks,
on the wall to the engine side below the battery. make sense? i installed it at a slight angle vertically, pointing towards the rear of the car. as you may have seen, the mount that the filter screws into is a big chunk o' metal that could be heated up by the engine near it.
Old 11-14-2002, 01:14 PM
Yes, I understand. I wonder if the fenderwell location is better in that you do not have to deal with the heat issue. On the other hand the filter change is more cumbersome. Hmmmm, heat vs. ease of change, decisions, decisions.
Mattski
98 Outback 180k
Old 11-14-2002, 03:41 PM
cbx-man cbx-man is offline
filter location
I did the same install and I mounted the filter on the passenger side. There is WAY more room over there for some reason!?!? And I mounted it horizontally so it makes changing oil less messy- oil doesn't run down the sides and onto your hands.
Alan makes a great suggestion for a heat shield, which I'll be making out of roof flashing and a poor man's bending brake.
I'll post photos as soon as I finish...
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 11-14-2002, 11:17 PM
Re: filter location
nope, i can't take credit - someone else suggested this a while back, but i can't remember who. i just verified it. i'm thinking its not so much that the actual fluid is being heated, but the sensor is, giving erroneous readings. with a heat shield, you'd get a more accurate temp reading on your gauge.
Old 11-15-2002, 11:54 AM
svxy's Avatar
svxy svxy is offline
Something like this...
http://www.jcwhitney.com/SearchCatCo...equestid=41088
96 Red SVX 96,000 miles
02 Toyota Highlander
02 Nissan Altima
04 VW Beetle GLS
Old 11-18-2002, 06:43 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Re: filter location
Landshark,
I think it was the mechanical engineer in me coming to the surface in the "Transmission Cooler" thread over in "Chris's SVX Shop". Glad to hear that the laws of thermodynamics still apply
My PermaCool filter is still in its box waiting to be installed -- Pics of your installation - with heat shielding - would be great!!
P.S. -- CBXMan should check the Transmission Cooler thread, since we worked over the "installed on the passenger side" issue as it relates to additional heat to the filter.
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-19-2002, 01:12 AM
Re: Re: Re: filter location
after thinking about putting a "permanent" heat shield around the filter and sensor, i have decided against it. i would have to cut and bend some sheetmetal, install it, and then un-install it every time i want to change the filter (and then install it again).
i have 2 15ft rolls of the insulated pipe wrap that i'll just cover the filter and sensor with. when its time to change the filter, i'll just put some new wrap on. much easier
Old 11-19-2002, 10:39 AM
SVXRide's Avatar
Alan,
Sounds like a plan...will the pipe wrap stand up to moisture and all the assorted junk that bounces up from the road? Is it your basic Home Depot/Lowes wrap?
-B
Old 11-19-2002, 11:23 AM
Re: Re: Re: Re: filter location
...i would have to cut and bend some sheetmetal, install it, and then un-install it every time i want to change the filter (and then install it again).
My thoughts would be to make the heat shield go over the top of the filter then down between it and the heat source and leave the bottom "open" for ease in filter changes...
cbx-man
Old 11-19-2002, 11:44 AM
it is a dense closed-cell adhesive foam with an aluminum backing, so it should be fine. its still there after the "quickie" job i did a week or so ago, with a lot of driving this week. i'll get under there sometime soon and do a better job - i just kinda slapped it on there from above. its pretty much above the undertray, so its not going to see alot of stuff flying at it. i got the stuff at Ace Hardware, but Home Depot/Lowes should have something that can be used.
Old 11-19-2002, 12:13 PM
SVXRide's Avatar
Alan,
Thanks. Did you just use the existing lines when you bolted in the permacool unit?
-B
Old 11-19-2002, 11:07 PM
Alan,
-B
i bypassed the radiator cooler and used an aftermarket cooler. i think i trimmed one of the stock lines, and used some of the line that came with the filter (or cooler, i forget.)
Old 07-01-2003, 05:33 PM
Well, I finally constructed and installed my transmition filter heat shield and it managed to lower the temp 15-30 degrees. Now it rarely goes above 180 in the city instead of the 195+++. Also, using the A/C helps to keep the tranny temps lower ( radiator fans always running )
cbx-man
