Gearshift Selector Lever lock - Won't disengage
I am working on replacing my factory head unit with a aftermarket stereo. I was able to disengage the Gearshift Selector Lever lock and move the shifter to "1" so that I could remove the stereo cage and audio door. I've installed the new head unit but now I can't get the shifter to come out of park without using the Gearshift Selector Lever lock override.
Have I done something wrong? I appreciate the help!! Yoshi |
Removing the center console
Did you push the screwdriver into the hole more than 1"? If so, you may have damaged the shift lock solenoid. ![]() First take a look at an exploded diagram of the shift lever... Diagram at SubaruParts.com (to navigate there from the SubaruParts home page, go [MAIN] [SVX] [199x xWD (choose your model)] [Steering System and Cable] [Selector System] ). Part 35173 is the solenoid, 35122 is the lock plate (a metal strip, about 1/2" wide and several inches long, hinged on an axle. The solenoid pulls it from the bottom; your screwdriver pushes the top end). To open the center console (this is from memory, so apologies if I forget anything):
Take a close look at the shift lock solenoid (perhaps with a flashlight), to see if it looks like you gouged it, broke the wires, or perhaps somehow unplugged it. Also look closely at the lock plate to see if you've bent it. The next step depends on what you see.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses Last edited by SVXdc; 06-05-2004 at 08:08 PM. |
Thanks I'll give it a shot
David,
Thank you, again. Your instructions were perfect! I was able to open it up and I found that with my incredible mechanical aptitude in trying to disegage the shift lock that I had caused some marring ("marring" means I ripped the masking tape and ripped a few of the wound wires) on the wire wound portion of the solenoid that pulls the plate. Nothing else looks damaged. I suppose that I need to hand over the $59 and get a new one from Subaru Parts.com (it says part will ship in 4-10 days, how long has it taken for you?). However, before I go and order a part that I don't need, do you think that kind of marring on the wound area of the solenoid could cause the whole thing to go bad? (the damage is about as big around as a thin screwdriver that could fit though the hole for the override. Regards, Yoshi Last edited by ykobayashi; 06-29-2003 at 08:43 AM. |
Solenoid repair 101
If you have to replace it, first I'd look around for used ones (junk yards, or For Sale posts). But you may be able to repair the damage. Remove the solenoid from the car so you can work on it in good light. Carefully remove all of the "masking tape" cover. Start at the outermost layer of the break and unwind the wire in both directions away from the break. Every few inches you'll come to a spot on the wire where your screwdriver nicked it (at the top of the coil). You want to get back to the first spot in each direction -- one will be fairly close to the solder joint where the wire harness connects to the solenoid, and the other will be in the opposite direction down the coil (which eventually winds all the way to the inside and comes back to the other solder joint). As long as you don't remove too many feet of coil, you can join the two broken ends and it will work again. As you unwind, you may start seeing places that are nicked but not broken. You'll have to use your judgement to decide whether to continue unwinding, or make that the point where you join to the other wire. If you're careful, you can solder the two ends together. Scrape off about 1/2" of insulation (the "shellac" that coats the wire). Unwind enough slack so that your solder joint is an inch or two away from the coil (so the heat won't melt the insulation further down the coil). Twist the ends together, and solder. Then insulate the solder joint (perhaps with a little heat-shrink tubing). Finally, cover the repair with a layer of tape. Regular masking tape might do, though that area gets warm, so I'm afraid it would eventually dry up and fall off (not sure what else to suggest, though). Good luck!
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
