Old 05-07-2003, 12:48 PM
96 SVX owner
can you help with my bucking ? ? ?
In warm / hot weather when I am doing slow turns I get a noise .....and the SVX bucks ....and.... clicks during the bucking as I am turning.
Is this AWD transmission ? ......differential ?? What should I do ?
---aside from trying not to turn ! ! ha ha
(I wish it was only my imagination)
Old 05-07-2003, 12:50 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
seems like diff but could be a ton of other things as well.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Earthworm's Avatar
Meow!
Is it binding as if the tranny was forcing 50/50 distribution or does it feel more like something in the steering system?
Old 05-07-2003, 01:15 PM
alacrity024
it could be something as simple as a cv axle..
-adam
Old 05-07-2003, 01:42 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
bucking
Does the power light (96's still had them right?) show that it has a trouble code in it? It'll blink like 15 times when you start the car rather than just coming on for a few seconds.
Old 05-07-2003, 02:03 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Re: can you help with my bucking ? ? ?
Sounds like the AWD is engaging when it shouldn't be. Could be a duty solenoid "C" going bad. I rectified mine by replacing the campaign filter and bypassing the stock cooler with an aftermarket one.
A 96 probably won't have either a campaign filter or a clogged stock cooler, so your Duty Solenoid "C" is probably failing. Most times it won't throw a code. Only the wrongful engagement of the AWD.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 05-07-2003, 02:22 PM
96 SVX owner
Smile Hey ...I like this site -- after my 1st posting - i got all the info ..thx
Old 05-07-2003, 06:00 PM
oab_au oab_au is offline
Stick the FWD fuse in the fuse box to disconnect the AWD system. If the trouble goes away it is the C solenoid, If it does not, it's some thing else.
One Arm Bloke.
Tell it like it is!
Old 05-07-2003, 06:21 PM
SVXPILOT SVXPILOT is offline
Have you changed the fluid. Mine started to bind when turning at parking lot speeds shortly after I bought it. changing the fluid stopped the binding. I now change the fluid every 10'000 miles. the clicking could be a bad cv joint.
Old 05-07-2003, 07:13 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
Just a minor aside...
If the FWD fuse is in, but the FWD light does not light up on the dash, it's probably the Duty Solenoid C as well. But in this scenario, the TCU should have registered the problem, and you should see a blinky Power light.
VK
Old 05-08-2003, 06:33 PM
VK
Yes it depends on if the solenoid has failed electrically or mechanically.
If it failed electrically the TCU will post a code. I have opened up a mechanically failed C solenoid and found that the return spring that returns the armature has broken up, jamming the armature from opening fully, thus applying pressure to the clutch.
One Arm Bloke.
Tell it like it is!
