Hey,
I have had this problem lately. Anytime I go around 60 mph lately been doing it around 50, the steering wheel shakes very badly. What is wrong? Roger |
Re: shaking
thrown wheel weights misalignment worn suspension bad driveshaft bad CV joints and probably more
i had that problem in an old car of mine...tie rods?
Kelli
Previous owner of the Princess Pearlie "Dimples" as of 8/6/03 1992 LS-L Pearl 124k "Yeah, that thingy!" owner of the new 1992 LS-L Pearl "Susie" I am a pessimistic optimistic. I think the worst is going to happen, that way when it does, i don't feel as bad, but if the best happens, i am twice as happy. |
Bad Tires Too
Sart with the balance and a check for loose components. To check the axle CV joints, dirve in a tight circle, and lightly hit the gas. Listen for poping, cracking noises. If everything checks out and you still have the problem it's the tires. |
more often then not this is cuased by not spin balanceing the tires, Get them remounted and balanced, see if that helps
phil
