Trevor, I made a copy of your TPS adjust post, if you want me to send a copy to you? (I don't know how to scan!?)
Or anyone else (via mail). ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
Beav you are spot on.
However surely the guys who designed things would have taken into account that a mechanical device, as is the TPS, could/will not provide a perfectly reliable smooth signal and therefore will have incorporated some slight time delay to cover this. No expense involved. I suggested a simple check based on what the average handy man could have available and am sure this would show up any fault which would be a problem. I did not think it worth while to set up my scope when checking mine. But !! the design of the electronics could be wanting and belt and braces could be called for !!?? I have not experimented with this but one could connect a few volts (dry cells or a limited current supply and NOT a car battery with lots of amps on hand and no fuse protection) across the element of the TPS together with headphones from wiper to one side, move the wiper and listen. A nice smooth rustle should prove all is OK. But anyone not understanding the basics and why I suggest this should not experiment.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
OK...So I read this post and decided to jump right in and try this myself (due to the annoyances of an occasional Check Engine Light at start up). I cleaned the throttle cables, throttle body, and MAF with choke/ carb cleaner. The car runs and drives exceptionally well afterwards. However, I never disassembled the TBS due to the accessibility and my ability (patience mostly). I noticed when I held the bodies open there was a lot of black soot (carbon?) deeper in side the unit. Is this common? Should I worry about taking the entire body off and cleaning it? Right now I have my baby in the shop (Suby dealer) getting the "codes" checked........Update..No codes came up, so I guess that's a good thing.
The black dust is from the TPS itself. Just a by-product of normal wear. The more dust, the more wear that has occured. No need to disassemble further if it's running o.k.
Trevor, I wish it were that easy, it would make my life less miserable. ![]() Newer control units employ fuzzy logic in some areas, such as ABS inputs, but I haven't witnessed any yet that can/will sort out an erratic signal. Too many times I've seen one or two spikes in a TPS or crank signal all but bring an engine to its knees. I agree, it's ridiculous to be that critical, especially considering the harsh enviroment of an automobile. One could easily build a conspiracy theory against the OEMs and back it up, as there is at least one GMM that knows enough about automotive signals that it will take 'snapshots' of a glitch as it occurs, unattended. ![]()
Beav if it is all as you say my heart goes out to you. However I think there is some confusion here between problems involving analogue as opposed to digital signals.
The TPS is a transducer with an analogue output . Or to be exact it varies an input voltage to provide an output voltage directly related to position. No counting of pulses is involved and if the designer has not incorporated at the very least a bypass capacitor in the input circuitry to smooth any slight Ò noise Ò in the signal, something is very wrong with his design. As an example the gas gauge would tend to flicker if the signal from the sender was not absolutely perfect and the read out was an instantly responsive display. However I have long felt that those involved in designing the electrical systems in cars would not last two seconds in other industries and if you are right you have proven the point.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 03-15-2003 at 02:13 AM. |
Dick ************** 1999 Legacy GT 30th Anniversary Edition 2001 Outback Sport |
