Is 5w-40 oil alright to use?
Is a 5w-40 weight oil alright to use in my SVX? I don't believe that weight was around when our cars were manufactured so there's no info in the manual about it. I'm looking at the full synthetic Rotella T6 5-40. We use it in our 05' Baja turbo and have had great results with it.
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
Re: Is 5w-40 oil alright to use?
Also I look at this these cars are many years old now unless you rebuilt the engine the tolerances are probably looser then stock so that thicker oil will help |
Unless you're in the Arctic, go for it. I run either the 5-40 or 0-40 T6 in my Legacy, depending on what's on sale. With blessings from Blackstone Labs I've been able to push my oil change intervals out to 10,000 KM (6000 miles), so between that and buying oil by the barrel I've managed to save quite a bit of money with Rotella.
Canadian Tire. I believe the 0-40 only comes in barrels though.
Been using 5w40 also and have no problems. The engine seems to like it.
The 0W-40 is a lot thinner when cold and flows into the tight clearances between the bearings, rings and oil passages of a newly rebuilt or newer engine. After breaking in my new engine with conventional oil (5 changes in 1000 miles) I started the 0W-40. The Mobil 1 0W40. It is closer to a 10W30 than a 10W40 at operating temperatures. It has an excellent HTHS viscosity, so it shouldn't shear even in an STi engine under stress. It also has great low temperature viscosity for cold climates. One other thing to note is that the Mobil 1 0W40 has a very high TBN value, which means it is great for extended oil change intervals.in my case every three years with only a filter change and new oil annually. If you want some extra seal conditioners to hold off leaks on notoriously leaky Subaru engines, either blend the M1 0W40 with the M1 5W30 HM or add Lubegard Bio/Tech Engine Protectant to the M1 0W40 oil. I was not looking for the seal conditioners of a high mileage oil , which you may need. The Lubegard product adds some seal conditioners and a special polar ester molecule that creates an additional protective coating on engine parts. The added ester film on the metal surface will help avoid damage when you start the car after it has sat for a long time. The recommendations were from Blackstone Labs, which does my used oil analysis. Along with consultations with Mobil 1 directly. .
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
svxcess,
Where's the best place to buy Lubegard Bio/Tech Engine Protectant?
https://www.amazon.com/Lubegard-3090.../dp/B0002JMLRE
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Running Mobil 1 5W-40 right now, 90-some thousand miles on the engine. Ran it for 10k miles last time and the old oil looks almost new. BUT, I'm not having my oil tested. So, all I can say for sure is that my car is still running well.
Weird coincidence, too, that I took a trip right after the oil change and got 28 mpg. Can't be the oil, right? Prior to that, I'd never recorded better than 24 mpg. |
I use the Castrol in my Audi A3, mainly because it's the cheapest when on sale. When Cdn Tire puts it 40% off it's less expensive than their house brand when it goes on sale at 35% off.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
For what its worth, I going to be switching from traditional M1 10w-30 Full Syn to M1 high mileage Full Syn: (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1).
Thread Tools | |
Display Modes | |
