Temp gage
I have a Tranny temp. gage that is no longer connected to the tranny as the auto was replaced with a standard. So I now I have a non functioning gage. Here is my dilemma , what can I use the gage for now? Any suggestion on what I can connect it to and how?
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. Last edited by Conn SVX; 05-02-2014 at 08:36 AM. |
Re: Temp gage
You can install a temp sensor in the drain plug of:
Then get a four way selector switch and you have access to all your oil temperatures. Or even drill and tap the thermostat cover and monitor radiator exit temp ![]() Tapani |
Re: Temp gage
I would actually be curious about the oil temp of the front diff.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
Re: Temp gage
Where would you attach the sensor? I like that idea.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
Re: Temp gage
First remove , then drill and tap the drain plug.
Re: Temp gage
See attachement
/T |
Re: Temp gage
Any lead on where to get the sensor?
Re: Temp gage
It has to be compatible with your gauge - so try the manufacturer.
I drilled and tapped (1/8 NPT in my case) the plug myself, but you can buy these too. The NPT thread is conical so you need to pay attention. Tapani |
Thread Tools | |
Display Modes | |
