Rear Brake line routing near gas tank
Could some one spell out how they route exactly?
I've got a leak in the lines someplace above the tank...I'm not pulling the tank right now. The junction in front of passenger rear wheel is ok and accessible... 2 lines go shooting up next to the gas tank...then on the other end of things, the brake line at the wheel is coming from the rear end of the car?? How is this thing routed!? So where is the nearest accessible (don't mind pulling a few things, but not the tank right now) point to splice after it comes out from the passenger compartment?
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! Last edited by zavikan; 03-08-2014 at 05:23 PM. |
Re: Rear Brake line routing near gas tank
Alright. I kind of answered my own question.
But....both lines disappear behind the tank, one atop the other, and reappear on the other side, but its not possible to see which one was the top line and which was the bottom line. Which is which? (this post has so many grammatical errors.......IM BUSY OK!?)
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! Last edited by zavikan; 03-09-2014 at 08:41 AM. |
You did remove the rear seat and see if you can see them right?
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
I see where they leave the rear seat and go under car. I can access that junction (if it disintegrates is a good question). But I don't know which line goes left and which goes right.
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
Is this of any use?
http://opposedforces.com/parts/svx/u...llustration_6/ /T edit: There's also a good illustration in the FSM. See page 56 in the appropriate section Last edited by Tapani; 03-09-2014 at 11:23 AM. |
Yes! I think....
The picture gets to pixelated....but it appears the top pipe goes to passenger side? Outside I go.. THANK YOU
Hard to tell - it may be the opposite.... see the attached illustration from the FSM
/T |
I would just replace both lines eliminating the junction point underneath. I did mine with two different colored pipes so I can know which side is which. I used flare fittings where they connect under the seats, this way I have access to them and they are safe from the elements. I pulled out the old pipes because they just fell apart from all the rust. I ran the new pipes along the frame secured with zip ties. I then cleaned the rusted areas and rubber coated everything.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 03-09-2014 at 07:48 PM. |
that will be very helpful for later this week…
I think the FSM shot DOES show the top going to the drivers side. which sucks…b/c now my drivers side goes to my passenger side…and the drivers side still leaked so I just blocked it off for the night. will need to fix it tomorrow night. Those pics will help as they tell me which line is which when it comes down, and the FSM shot is SO much better then the pixelated thing… thanks guys J
Thanks |
Brake Line Repair for SVX rear;
Two brake lines PAJ-351 (R+L)-----------------$18.00 Brake line PAJ-320----------------------------------$6.00 Brake line PAJ-312----------------------------------$6.00 Two brass unions BLU9C--------------------------$9.00 One can truck bed liner to protect brake lines--$11.00 Special clips to hold lines to body-----------------$4.00 Valvoline Synthetic fluid---------------------------$7.00 Parts--------------------------------------------------$61.00 Rear fitting goes to the RR wheel, Front fitting goes to the LR wheel.
What are those part numbers? PAJ-351 etc.
Advance Auto Parts numbers for a bend it yourself brake line replacement.
You might need others or different ones because its a bend it as you go deal.
PAJ indicates a Japanese fitting, the 3 indicates 3/16" diameter line and the 51 is the inches in length.
Thread Tools | |
Display Modes | |
