Custom DIN slot cup holder
I just completed my custom cup holder. It is made from Plexiglass. I replaced the double din stereo with a single din Pioneer. I put that in the lower din slot. In the upper din slot I installed a pocket. There are two upper and two lower rubber foam strips on the sides of the plexiglass to hold it firmly in the pocket and provide some stabilization or shock absorption. There are two plastic clips holding a steel rod which swings down to hold straight sided bottles. There is a Neodymium magnet glued to the plexiglass to hold the steel rod out of the way for tapered travel mugs.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 08-25-2013 at 12:33 PM. |
Re: Custom DIN slot cup holder
![]() You MADE THAT! Very cool! ![]() Can it fit an Asti bottle? ![]()
A half-bottle perhaps. Asti is just Moscato. There are some wineries that actually make half-bottles of the stuff. In fact, you can get half bottles of Moscato Ice Wine. REALLY good stuff. I will put a bottle in there and see if it holds it.........
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
[QUOTE=svxfiles;727611]
![]() You MADE THAT! Very cool! ![]() +1!!!!
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
I have found (and ordered) OT's favorite in both the 375ml and the mini 187ml bottles.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
I'd like to see a picture with a bottle or can inside it.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
What kind? Unless it is too big for the hole it would look like my pics but with a bottle inside.
It seems like an awkward place to put a drink but it looks well done.
Nice work, would it fit if you swapped it and the stereo?
current stable, subject to change without notice: ![]() 1995 Red SVX, 4.44 & Quick Change 2014 Nissan Titan S 4X4 1992 Teal SVX parts car |
If you use a tapered travel mug and flip up the steel rod, spilt coffee will run down the top surface and into the pocket where it is held nicely (assuming we are talking a small spill here) until you can remove the holder and clean up the mess. I don't drink soda. An accident with a water bottle is minor, again, assuming a small spill.
It would be pretty cool to put some LEDs mounted to the back side of the plexi and do a notch like thing around the outside to give it a lit border kind of a thing. That's how the cup holder in my Volvo is and it gives it such a neat look at night. One LED generates this entire ring of light because of how the plastic of the cup holder is notched. It works kind of like how the BMW angel eyes work.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
That would be easy to do but I polished the edges of my holder so they won't scatter much light.
Not bad Husky. Does it slide in when not in use?
Thread Tools | |
Display Modes | |
