hesitation and running issues.
I am having hesitation issues.
Very random. Worse when cold... but still there when warm. I have replaced O2 sensors(ngk) Spark plugs (ngk laser iridium) Knock sensors Coolant temp sensor (oem) MAF (twice) TPS (and tested to make sure it is fine and adjusted with meter) Cam and crank sensors Intake gaskets Alternator (maniac) All vacuum hoses under intake Fuel filter AND 6 new fuel injectors. Any one got any other ideas? Anyone know of somewhere in central Florida I could take it and get reputable service? Last edited by steveherman; 07-13-2012 at 08:59 PM. |
Re: hesitation and running issues.
I would suspect one or more bad coil packs. I had similar issues and that was the culprit.
Have a look at the intake right before it gets to the throttle bodies. The big plastic one. There are many nipples for large hoses to connect to. Maybe one of them is cracked and has a leak.
Another thing that comes to mind is the engine/chassis/battery grounds. Make sure they are all good and solid. You can add an engine>battery ground if you want to as well.
Same with me.
ARMANDO 1992 SVX LS-L "Black Beauty" 292,500K (purchased April, 1997 w/65K) http://i1259.photobucket.com/albums/...psz1xmhtdo.jpg 1992 SVX LS-L "Blanca" 214,000K http://i1259.photobucket.com/albums/...pskv0odesa.jpg 2004 Mazda RX-8 http://i1259.photobucket.com/albums/...ps7vggfwfu.jpg 1974 Mazda RX-4 http://i1259.photobucket.com/albums/...psentjrygb.jpg |
is there a way to test them to see if one is the culprit and which one? |
With the car running and hesitation present, disconnect one at a time. If the hesitation gets worse, that one is OK. If the hesitation stays the same you've found your man. If more than one is bad you could leave the bad one disconnected and continue to pull one at a time and see if there is any change.
After I changed my plugs and one bad coil I broke down and brought it in to a local Subaru specialist. He diagnosed and replaced another bad coil with a spare I supplied. |
also it is only when driving. idle is so smooth |
I have some spare coil packs you could use to diagnose whether one is bad.
I would try the coils as well. I had this issue, one of my coils was lazy. It would work occationally and not at full strength. Borrow the coils and try one at a time, drive with it for awhile and then switch to the next one until you find the bad one. Time consuming but worth the effort.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
At what rpm range do you experience this? I swear I've done everything you have and my vehicle does this mostly when the engine is at temperature.
The only things I haven't done were replace the complete throttle body and place in a new IRIS valve. |
2200 to 2300 rpm is the most common. |
curious, did you resolve your issue?
If it ain't broken it, doesn't have enough features!!! '92 SVX LSL '03 4Runner '96 FZJ80 Landcruiser '90 Mercedes 300E |
no
getting worse... hopefully will throw a code... frustrated |
Do you have a stage1av1 chip?
Not yet.
Hopeully next paycheck. |
Thread Tools | |
Display Modes | |
