Gauges
They are from prosport, and I used a oil filter adapter for the oil pressure and temp gauges. I also got a oil galley plug, so once I get the other motor built, I will put the gauge directly in the block. They are the 45mm ones, which I got because I really don't see anywhere else in the SVX interior other than a DIN slot that they wouldn't look completely out of place and awkward. Once I have the water temp gauge hooked up I will take a video. As far as installation, I just used a sheet of plastic (actually a mouspad I don't like at all) I had and cut/folded it into the shape of a DIN slot, then cut circles in it. The color and texture look like what you'd expect to see in a car, so I guess it works.
Re: Gauges
Nice work! They look good! Looking forward to seeing the video for sure!
1994 subaru svx le 112k Last edited by Subix; 06-21-2012 at 02:11 AM. Reason: e |
Re: Gauges
Sir, you have a game that ruins lives in your passenger footwell. You're going to have to get rid of that asap.
http://i840.photobucket.com/albums/z...93705d9zzz.png |
Re: Gauges
VERY nice I like it. I have one Gage , the one to the left of the cluster, that was originally for Tranny temp. since I no longer have a Auto tranny, I need to replace it or set it up for another use ?????? Any suggestions?
Re: Gauges
Not sure if they make them for the svx but a pillar 3 gauge pod would probably work better, looking down that far to see them just seems like asking for trouble lol
Re: Gauges
Conn, those look good. Yet another thing that's very similar about our cars. Yours look a little bit bigger though, right? You have a white back speedo/tach, right? Bet the gauges match nicely then. Your trans temp one, you might be able to re-purpose, but I'm not sure. What brand are they? Thanks, all. Gonna try and finish up the rest tonight.
Re: Gauges
Re: Gauges
That would be WC3, not WoW, sir. Can only be described as a well-aged classic. A friend of mine had it sliding around in the trunk of his Altima for like 4 years, and cleaned the car out next to mine. Guess where it ended up. Not sure what to do with it.
Re: Gauges
Nate, you're going to laugh when you get here and see where I ran the wires... :P
Re: Gauges
Innovate wide band and boost
T |
Re: Gauges
I'm intrigued...
Re: Gauges
I just saw Warcraft. Either way...DOWN WITH BLIZZARD
Re: Gauges
Now have amp and vac. Where do they get the temp.for tranny taken from? Could I move the sensor to the oil?
Re: Gauges
Before WoW, blizzard was a very different type of company. Like, night-and-day.
Re: Gauges
Mine are Summit VDO gauges. The dash is Procarparts reverse Euro indigo
Thread Tools | |
Display Modes | |
