Is the stock tailpipe stainless steel?
I want to add a small piece of flex pipe in the tail pipe right after my 2-to-1 stock cat.
The flex bolts rusted away and I bolted the flange right to the cat with straight bolts, so the system lost a bit of flex and it's putting some stress on the tailpipe-muffler joint. Anyway, my question is, is the tailpipe stainless steel? It certainly does not look like it. Will this work to cut it? http://www.amazon.com/gp/product/B00...pf_rd_i=507846 Also, got the SVX out after being on jackstands in the garage for 10 months. Ran perfectly! Except, of course, the exhaust. |
Re: Is the stock tailpipe stainless steel?
Yes.........
even stainless can rust when it is paired with steel....
Two 44059AA010 bolts Two 902350004 nuts Two 44028PA000 springs
any idea on cost ? for the above parts ?
About $8.00 for the pair of bolts,
about $2.00 for the nuts, about $16.00 for the springs IF they are missing, or if you had to cut them to get it apart. Normally those springs last forever, unless they are damaged.
I've found that honda spring bolts are an exact match for ours, and are available aftermarket for just $2.42 a pair for the entire bolt/nut/spring set. Just a tip!
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
they make a two piece collar flange that you can install around the original if yours is too rusty. it's just two curved pieces that the bolts go through.
Mike, any chance you know the part numbers, or the year and model?
2000 civic, or many other years, and models too I would imagine.
I will buy a pair and check them out.
We used them on an outback here and they worked perfect. Compared them directly to SVX bolts as well. Though not identical, they work perfectly
Thread Tools | |
Display Modes | |
