READING THIRTEEN sign up list
You can also add to the list on the 20 / 13 meet HERE
1. John Hoffman - "svxcess" 2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Rob Sgarlata - "LetItSnow" 5. Tom Krynock - "svxfiles" 6. David Caron - "B 4 You" 7. Andrew Goldstein - "Jellybytes2" 8. Jake Schmidt - "JakeSVX"
Re: READING THIRTEEN sign up list
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Rob Sgarlata - "LetItSnow" 5. Tom Krynock - "svxfiles" 6. David Caron - "B 4 You" 7. Andrew Goldstein - "Jellybytes2" 8. Jake Schmidt - "JakeSVX" 9. Sean Leitz - "Sean486"
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486"
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX"
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX" 10 Huck "Huck369" ...hoping to attend
Im finally going to make it! only in a Volvo
1. John Hoffman - "svxcess" 2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX" 10 Huck "Huck369" ...hoping to attend 11. Eric - "SomethingElse"
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX" 10 Huck "Huck369" ...hoping to attend 11. Eric - "SomethingElse" 12. Tony - "Huskymaniac"
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX" 10 Huck "Huck369" ...hoping to attend 11. Eric - "SomethingElse" 12. Tony - "Huskymaniac" 13. Mike Milan - "Mike621" Depending on how finals start wrapping up, I should be able to make it!
1991 SVX L JDM |
I thought I had already signed up, but apparently NOT; So here I am .....
1. John Hoffman - "svxcess" 2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX" 10 Huck "Huck369" ...hoping to attend 11. Eric - "SomethingElse" 12. Tony - "Huskymaniac" 13. Mike Milan - "Mike621" 14. Harry Newman - "newsvx"
newsvx 1992 SVX LSL, #1215 1997 SVX LSi, #370 "I live with fear every day. Sometimes she lets me go racing." "Getting Older and Slower" Locker: http://www.subaru-svx.net/photos/user.php?newsvx |
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX" 10 Huck "Huck369" ...hoping to attend 11. Eric - "SomethingElse" 12. Tony - "Huskymaniac" 13. Mike Milan - "Mike621" 14. Harry Newman - "newsvx" 15. Marisa Ramon - "cozykat"
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
15 signed up so far...
and 6 rooms ( 10 beds) reserved. This is going to be a cozy meet indeed. .
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX" 10 Huck "Huck369" ...hoping to attend 11. Eric - "SomethingElse" 12. Tony - "Huskymaniac" 13. Mike Milan - "Mike621" 14. Harry Newman - "newsvx" 15. Marisa Ramon - "cozykat" 16. Brian - "DiabloScoobyru" Count me in ) May be in the shop van with the car on a trailer behind me, but I'll be there it looks like I'm 25 minutes away from Morgantown (if not less), and if necessary I may be able to put someone up for a night here at the house. |
Don't tell Di!
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 01-15-2012 at 03:01 PM. |
[QUOTE=DiabloScoobyru;695010]1. John Hoffman - "svxcess"
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX" 10 Huck "Huck369" ...hoping to attend 11. Eric - "SomethingElse" 12. Tony - "Huskymaniac" 13. Mike Milan - "Mike621" 14. Harry Newman - "newsvx" 15. Marisa Ramon - "cozykat" 16. Brian - "DiabloScoobyru" 17. Ron M - w/wine & Cheryl
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
quote=DiabloScoobyru;695010]1. John Hoffman - "svxcess"
2. Earl Steele - "ensteele" 3. Elazar Mann - "radarwhiz" 4. Tom Krynock - "svxfiles" 5. David Caron - "B 4 You" 6. Andrew Goldstein - "Jellybytes2" 7. Jake Schmidt - "JakeSVX" 8. Sean Leitz - "Sean486" 9. Mike Davis - "Green1995SVX" 10 Huck "Huck369" ...hoping to attend 11. Eric - "SomethingElse" 12. Tony - "Huskymaniac" 13. Mike Milan - "Mike621" 14. Harry Newman - "newsvx" 15. Marisa Ramon - "cozykat" 16. Brian - "DiabloScoobyru" 17. Ron M - w/wine & Cheryl 18. Chris - "SVXMAN2001" |
Thread Tools | |
Display Modes | Rate This Thread |
