torque converter bolts
anyone got any tips on getting the torque converter bolts out? i cant even get a 1/4'' woble socket on them
Re: torque converter bolts
Unbolt the alternator and use a couple long extensions from the front of the engine.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
What He said,Mostly!
Actually, I believe you did say that, a time or 20
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
I don't has a 48" extension.
well 2 24 inch will do also or 4 12 inch etc you could even take it to 48 1 inch extensions lol
William Last edited by subarufamily; 03-14-2010 at 05:02 AM. Reason: forgot to aDD lol |
Tape those extensions together so you don't have to scream when the connection pops loose in the middle and you struggle to fish the pieces out.
If I was going to do it that way I would use a LOCKING EXTENSION. But hey, if you wanna use tape...
I always got mine with no problem by using a swivel head snap-on ratchet and a standard 12mm socket. A knock off but competent can be found at lowe's for those not wanting to spend upwards of $100 for a ratchet. The snap on variant I love dearly is this one, minus the gross handle. http://buy1.snapon.com/catalog/item....re&dir=catalog But as I said lowe's has a knock off for like 30 or so I believe
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
Where's the challenge in that ??
any tricks on getting the dang diff and tranny out? got all bolts out tranny lines disconnected, shift cable off, and everything but i cant seem to get the diff n tranny off the 2 studs far enough to drop it down
You certified techs and your fancy tools
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 03-14-2010 at 11:52 AM. |
Lift up the front of the engine.
Thread Tools | |
Display Modes | |
