Is your H6 buttery smooth?
Just curious but how many here can claim their SVX to be running top-notch, as in liquid smooth with the engine humming so peacefully you can barely notice it's running? (and if so at what mileage?)
I'm not sure if it's because it's a boxer (as I have no other SVX alongside to make a comparison on) or because I most likely have some more coil packs that are losing out but I hopped back into the impreza for a spin and I just want my SVX to run that smooth at idle. (and that thing has 190k on it!) Or better, can it or should it? Has anyone here ever replaced every single coil pack and can say for certain it made a huge difference or not? I'm about to plunk roughly $600 in much needed new tires and I can't get the idea out of my mind in wanting to go ahead and replace the other 5 coil packs in hopes that everything will run smoother. Of course, that comes at a cost of only $400 ...but given the fact that nothing looked wrong at all with the coil pack I replaced, I can only suspect the others could just be worn enough in needing replaced. It is, afterall... 168k on the same coil packs. It does have a new set of NGKs however. Is there a general rule of thumb for life expectancy for coil packs anyways? I'm going to go ahead and replace my gas cap, fuel filter and pcv valve to see if that makes any noticeable difference at all but I'm betting it's completely unrelated and will have no positive effect.
1994 subaru svx le 112k |
Re: Is your H6 buttery smooth?
All of my cars run smooth. One more than the others sometimes. My claret especially runs smooth. It has about 123k now. And so you know...I have replaced a single coil pack and it made a huge difference.
Rebecca 92 Claret SVX LS-L (180k) 09/91 #5,732 06 Suzuki Boulevard M50 7k 68 Cadillac Coupe DeVille (70k) Storage/hibernation for now. Past SVXs: 94 SVX Emerald Pearl FWD (Sold) 96 SVX Bourdeaux LSi (Sold) 92 Pearl SVX LSL "Stay Puft" 5MT (140k) #148 (RIP) 95 Brilliant Red SVX LS (162k) 12/94 #564 "Killer Tomato" (RIP) |
My ebony runs mint and idles as quiet as any new car that I have ever sat in...
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
At idle I've sometimes forgotten my car is running. I can't hear or feel anything. I've gotten into the habit that if I sit in it for a while I take a quick look at the tach to see if it's still running or not, I tried to start it once while it was idling. Not a nice noise. On the road, not so much, but that's mainly due to my huge exhaust leak and the noisy tires I have.
Mine runs smooth once the coil pack warms up
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
mine doesn't run,
1991 xt6 eg33? 1993 gc track car |
Mine's smooth once it starts. (What's the over/under on how many times you have to turn the key this time? My friends are such cards.)
I've zapped the flywheel at least twice. It's good, but surely not undetectable.
Disclaimer: The above post is on the internet. |
Mine runs pretty darn smooth. Idle is ROCK solid since I switched over to iridium plugs, and I get just a hair over 30 mpg on the highway.
I have just a bit over 120k, and I have no idea if any of the coils have been replaced. I'm curious though about replacing my coils with some aftermarket ones, like the plasma direct coils that some of the other guys run. I figured one for a WRX would work, but maybe I'm wrong?! Is there an aftermarket coil that works with our cars? If anything, it can't be too hard. Maybe get a clip off another coil harness to make everything work?
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Nevin,
AFAIK the Impreza and Legacy do not use the coil on plug design the SVX does. They use a single coil pack and spark-plug wires. I had the good fortune to replace all 6 on my '93 and it made a huge difference. Examining the old ones I found that the wiring insulation at the pack was broken down, and apparently the cause of some spark leakage. OH! The engine in my new '97 runs smooth as butter!! Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Let me go look it up quick and see what I find. *pause* That's what led me to believe that ours were in some way compatable with theirs. http://www.okadaprojects.com/usa/products_direct.htm OK... *moments later* The very first one they have listed is for Subaru, so I'm just curious if the one listed is simliar enough to ours to run it. They have it listed for Impreza, Legacy, Forester, and Outback. Are those different than our coils?
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! Last edited by Nevin; 09-26-2008 at 10:10 PM. |
The coil-pack on my Legacy sits atop the motor with simple plug wires running from there to the plugs. Each half of the coil provides spark to 2 cylinders. I don't believe they have changed the design since my '98 EJ25 was built. Wouldn't be the 1st time I was wrong though! Anyone?
Glenn
My ebony runs extremely smooth. I often think it has stalled on me
The rest of the car is in "ok" shape, but that engine purrs. And boy-o-boy does it pull hard The '95 has alittle hick-up and a few vibrations. Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
My 96 Polo idles smooth as silk, once I get it started. Svxfiles did head gaskets and machined heads last month. Ignition switch is loose and doesnt start properly. Hope to fix tomorrow.
1995 POLO LSI 76K MILES SOLD |
EDIT: According to the application guide listed above, coil-over-plug is found on the turbo engines and the EZ30. OK... now what?
Disclaimer: The above post is on the internet. Last edited by LetItSnow; 09-27-2008 at 04:24 AM. |
my teal one idles/runs/accelerates very smooth. she still has 3.54 gears in there. my friend who drives a civic when he listens to my teal svx warming up in the winter....he said: "wow, that noise is smooth "
but this is what was happened - http://www.subaru-svx.net/forum/showthread.php?t=45935 my yellow one has double the mileages of the other one. i do feel the difference. it's still okay but i can feel it sounds a bit loose compared to the other one.
-SSSVX 92 LS-L TEAL since Aug '01 92 LS-L YELLOW since Mar '05 |
Thread Tools | |
Display Modes | |
