Tires
My '92 SVX needs 4 new shoes. The old Yokohama AVS dB S2s are almost all worn down. They have been a good tire. But now they are quite noisy.
I have the stock size 225-50-16 and usually like to run ultra-high performance all season tires. I've narrowed it down to two different tires. The first is the Pirelli P-Zero Nero M&S, and the second is the TOYO Proxes 4. I can get the 4 TOYOs installed, mounted, & balanced for about $80 (total) less than the Pirellis. I'd like any SVXers who have these 2 tires mounted on their cars to post good and bad comments (reviews) of them. I'd prefer posts from SVXers that have at least 2,000 miles on these tires and live in snowy, or semi-snowy climates. John H., I know you have the TOYOs. What has been your experience? Thanks in advance for the replies.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net ![]() ![]() Last edited by LarryIII; 04-02-2008 at 04:58 AM. |
I've got the proxes on mine, they were on when i bought it in feb.
they seem to be a good grippin tire, not sure about wear. though you can forget about any real traction when it's snowy. or maybe i'm just used to truck tires ![]() when i replace these tires later this summer, i'm goin w/ 18's and bfg kdw's and then run hanook snow tires on stock rims for winter.
WFO! http://www.cardomain.com/id/Schralper "You all laugh cuz I'm different I laught cuz you're all the same." |
Larry,
Definitely go with the Toyo Proxes4 I am running my second set of them and Pete just had a second set put on Olu's old pearlie. I can't be any more pleased with them. And svxcess is sometimes very hard to please. They are very quiet, responsive and have excellent wet and dry traction and in snow. I got great mileage from them and no problem with them in Maryland winters. Svxcess guarantees that you will love them. Something around $95.00 each. Check THIS THREAD for a little more information from me and comments of other members with this tire Paul at Radial Tire told me long ago that the Yokohama AVS db tires were quiet when new but got progressively noisier during the last half of their life. Sort of sounding like a bad wheel bearing. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
The original set of Yokohamas that came with the car, and the Avid V4 tires I had put on after both became noisy towards the end of their tire life.
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
When I bought my 95 it came with new Toyo Proxes 4 tires on the stock wheels. A very good tire in my assessment in rain and dry conditions & not at all noisy. I switched up to 17" wheels and 225/45/17 Nero Zero M&S and although I sense a little more tire noise, the grip is better. They aren't a good choice for real winter driving but in wet or dry conditions, they do a better job. Gotta keep in mind though that the difference in the tire profiles also contributes to the observed improvement. If you factor cost in, you may well be better off with the Proxes 4 and I would speculate longer wear with the Toyo's also. Just my .02$
Thanks everyone for the input.
I originally wanted to get Conti-Extreme Contacts a few years ago but got the AVS dB- S2s because the Contis were always out of stock. I have been following reviews of the Contis since then and they seem to be either very very good or downright horrible. That tells me that Continental has inconsistent production quality control issues with this tire. This time I'll probably replace the Yoko AVS db S2s with the TOYO Proxes4s.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net ![]() ![]() Last edited by LarryIII; 04-03-2008 at 05:05 AM. |
Making sure I understand this right...
![]() ![]() ![]() Either way, thanks Svxcess!! Keith |
I've got the Pirelli Pzeros on my car and I hate them....Had them for over 7,000 miles and they are the noisiest tires.
Save your money on these and get Toyos |
When I bought the car it had two Proxes and two Yokohama's on it. That makes it kind of hard to judge, but the tires performed well for the short time they were on the car before I installed a matching set of Blizzaks.
I work at a tire shop and my boss says the best tire you can buy is Goodyear Triple Tread. Goodyear rates them 10 out of 10 on dry, 10 on wet, 10 in snow, I think 9 on tread ware and 8 on road noise.
Actually saw an SVX that came in and I asked my boss if I can do the work on it. He said fine, but tell me one thing, why do you like those cars so much. ![]() ![]() ![]() ![]() ![]() ![]()
1992 Subaru SVX LS-L #5045 Dark Teal 1992 Subaru Loyale Wagon Gray (SOLD) 1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD) 1969 Subaru 360 Deluxe Ivory White 2005 Subaru Impreza WRX STi World Rally Blue 1993 Subaru Legacy L Wagon Teal Metallic (SOLD) 1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl [SIGPIC][/SIGPIC] |
Amazing All Season Tires
http://www.tirerack.com/tires/tests/...y.jsp?ttid=106
The new BFG g-Force Super Sport All Season tires tested as fast as the best summer tires and there's a video of them going uphill in the snow on tires.com. At under $120 a tire shipped with a 400 treadwear I wish I had saved for them ![]() |
Re: Tires
Toyo Proxes4 = best tires I have EVER had on ANY of my cars. I put roughly 5000 miles on the set which was on my Pearlie, but I gave them up with the car when I sold it to Nate.
1991 SVX L JDM |
Thread Tools | |
Display Modes | |
