The best wheel offset calculator...
Stumbled across this tonight when trying to figure out the change in characteristics after I install the '93 RX-7 wheels I secured today:
http://marksink.com/tire_wheel_offset/offset.html This calculator can be very helpful for people looking to figure out whether aftermarket 17" or 18" rims will work with the SVX. For my calculations I used the following specs: Stock SVX wheel specs are: 16x7.5 with a +55mm offset Gen 3 RX-7 wheel specs are: 16x8.0 with a 50mm offset New characteristics: "The clearance from strut housing to the inside of the wheel will be 1mm LESS The outside edge of the wheel will EXTEND an extra 11mm" I know these wheels will work great w/o rubbing issues as SVXRide AutoX's with them on his '92 LS-L. They weigh 16lbs each (stock SVX rims weigh 20lbs), so I'll shave 16lbs of unsprung weight after installation. However, I won't be able to put them on until Winter is over, as the seller included some barely used Dunlop Sport SP9000 max performance summer tires. -Chike P.S. A handling plus of installing these wheels is that the front and rear track on my car are widened by 22mm.
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 07-11-2005 at 08:21 PM. |
Here's another example:
My friend Svxfiles got some 17" lightweight Locos from Dayle a few months back. The specs for the Locos are: 17x7" with a 38mm offset New characteristics are: "The clearance from strut housing to the inside of the wheel will be 23mm MORE The outside edge of the wheel will EXTEND an extra 11mm" So the front and rear track on Tom's SVX will also be 22mm wider and there will be a greater clearance between the inside of the rim and the strut. -Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 12-25-2004 at 08:42 PM. |
Cool find. This means that maybe those 18 X 8.5s will fit, if the offset is 42mm, it'll be the same clearance on the inside. Super.
PS: Merry Christmas |
-Chike
why not bump out the rear fenders a tad? It'd make the SVX look even more serious.
-Chike
One cool thing...
I learnt today when I spoke with the seller of the RX-7 rims is that with the max performance Dunlop Sport SP9000's, the wheel & tire combo weigh ~38lbs each!
My all-season M+S Bridegstones with the stock wheels weigh 47lbs each on my digital scale, probably due to the extra reinforcements built into the tire. This means I'll be shaving 8.5-9lbs per corner when I install these new rims and tires - or a total of 34-36lbs! -Chike
Re: The best wheel offset calculator...
Your car will tend to wander a little more at speed, I would guess.
Re: Re: The best wheel offset calculator...
-Chike P.S. Either way guys, after completing these winter mods, I'll turn my focus to some mods in the handling department in the Spring/Summer. Namely Mychailo's stiffer springs, urethane bushings, and some thicker sway bars.
-Chike P.S. Still would be cheaper though to do a 4 wheel alignment. However, wider rear fenders would look awesome!
Nice looking car by the way, Oh, wait...
http://store.yahoo.com/svx-motorspor...es/moriii.html -Chike
I'm going to take them off this week to install my 245/45/16s on factory wheels for the winter. So I guess now, I'll have to measure them.
But I would not have bought them if they were 38mm. Stock is 55mm, right?
Thread Tools | |
Display Modes | |
