#91
Re: alternator wires
#92
call your local auto parts supplier and see if they can order it, thats what i did, took 2 days and order an extra fuse in case a)one's a dud b) you blow it on the road
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
#93
Yes, hence the "few weeks" till I'll be doing mine. But I'm not exactly in a hurry, got plenty of other projects going on. Anyway, I meant that more for future reference than right now.
#94
More than a little frustrated..
Followed the instructions for the wire upgrade..... buttoned it up... and I get : Battery light, Steering, ABS, Stoplamp.... sigh.... I think I screwed up a splice...... Voltage to the battery is good.... all the fuses have power... I'm stumped
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
#95
Check the small wires going to the plug on the alt.
#96
The plug is brittle and one of the wires that I spliced did come lose... but I have to be off to work... I'll check it tomorrow... also...anyone know if there are replacement plugs for the alternator?
Mitch Hansen
#97
what are those wires in the plug for?
#98
My original source used to be Northwest Regulator Supply. They only deal with manufacturers now. But you can buy them directly from their distributor Electric Motor Service in Logan, WV. Their phone number is 800- 697-6070 The part number is 050-012252 and they go for $9.53 each plus shipping with no minimum. I already ordered two more. .
#99
On the plastic connector, one wire is the field sense wire, that energizes the alternator when the ignition is on. Also monitors battery voltage and uses the regulator to supply additional voltage on demand The other wire goes to the idiot light on the dash, turning it off when the alternator is charging. If you are replacing the plug, make sure to keep the wires from getting switched around. Remove only one wire at a time and reconnect to the new plug to avoid confusion.. The original OEM plug has two wires of different thicknesses, the replacement plug has both wires the same size. Mark them however you want when changing them. . .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-03-2011 at 03:03 PM. |
#100
no but it's mine and I'm pictured.. terrible side shot. I have since took off the upgrade, since it blew an alternator or it's the only explanation. well perhaps a bad one from the shop. I left the negative ground in place.. now It's time to GET another alternator.. I still have my OEM core.. Yes I want it for a rebuild. got the other from Napa lifetime replacement and I think it's an HO.. not the 160 that I'd like to put.. perhaps I need to re investigate these wiring upgrades, from earth grounds, battery, alternator and so forth. As I do have a few things I wanna add.. HIDs for one.. and perhaps a sound upgrade.. I dunno need to find the wires or order.. I remember long ago Beave saying there needed to be an In Line fuse.. Glad it got included.
Happy driving to all. svx1999 |
#101
Mitch Hansen
#102
Ok...wiring is done...and working...interesting side note..... for the past 3 years I've had to push the sunroof to start it when I wanted it opened...today..after all the wiring to the alternator was redone..... I just pressed the button and it opened by itself....whodathought?
Mitch Hansen
#103
i have found that the wiring mod can increase battery voltage by almost 2 volts. in the case of your tired sunroof motor, that may be all it needed to bring it back to proper health. Glad everything is back to normal. in the world of gremlins, the electrical ones have got to be the worst! .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-04-2011 at 04:53 PM. |
#104
I still have the code 34 EGR solenoid to hash out... but somehow.... that doesn't seem as important now that I'm not stalling out from a standing start.
Mitch Hansen
#105
OK.... raining and cold here...went for a longish drive 30 miles, parked, and on the way back it's almost like my car rebooted... ABS light came on...clock reset... I'm thinking I have a short on the alternator wire I've just replaced.... any other ideas?
Mitch Hansen
Thread Tools | |
Display Modes | |
