Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
  #91
Old 01-16-2012, 06:23 PM
Re: SVX Straight line performance
Originally Posted by Hocrest View Post
Is your trans broken? or are you trying to break it??
Originally Posted by oab_au View Post
Well luckily ,,,, he is just down the road from you, when it happens.
But fwd burnouts are teh koolest!
Old 01-16-2012, 07:20 PM
But fwd blowups are teh koolest!
There, fix your post.
Old 01-16-2012, 11:52 PM
Youse Guys are just mean!
Old 07-08-2012, 10:56 AM
svxhunter svxhunter is offline
5 speeds rock! :D
Tomssvx: 12.99@106 with Hydra powered S/C 3.90 6 spd. (S/C 6 spd. SVX record)
PoweredX2: 13.2 with 3.70 auto FWD and nitrous(Nitrous & FWD SVX record)
Benebob: 14.2 with 4.11 auto N/A grassroots racer(4.11 auto N/A SVX record)
Tomssvx: 14.5 with 4.11 5 spd. N/A(4.11 5 spd. N/A SVX record)
Phastsvx: 14.5 with 4.11 5 spd. turbo (4.11 5 spd. turbo SVX record)
Budfreak: 14.9 with 4.44 auto N/A(4.44 auto N/A SVX record)
Chris: 15.2 w/ stock auto
Tee hee
I think you are missing one.
My car (The SVreX) ran 13.8 at the Grassroots Motorsports Challenge in 2004. It was AWD stock slushbox and gears. It was pretty stripped, and had a 75 shot of nitrous.
Never tried to do better, but I see no one else has either!
'92 LS-not-so-L: the "SVreX"- Saved from a crusher, an SVX racer built by home schooled students for less than $2000 (including purchase price). 13.8 second 1/4 mile. Autocrossing monster!!
'92 LS-L Claret: '01 RS 4:11 5-speed, Exedy organic, lightened flywheel, and Koni/ GC
Old 01-27-2019, 05:07 AM
jeffs92svx jeffs92svx is offline
Man, I haven't been on here in years, use Facebook now. Anyway 8 years later and still using fwd about 95% of the time, no problems yet. Tranny wise, plenty other though
92 claret-87 xt turbo-93 z28 6 speed-06 cobalt SS
Old 02-03-2019, 05:01 PM
kultur kultur is offline
It's so crazy to think you can drive the car in FWD for eight years and nothing happens. That couldn't have caused your transmission issues?
Old 02-04-2019, 03:22 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
What about cars with the Gear Firm-Up Unit (QC) added ???
OR
The Power Mod ???
Old 02-05-2019, 12:23 PM
OR
The Power Mod ???
In respect of the QC which certainly has no "firm-up" action, an acknowledged expert within this forum has advised:-
" Within the solenoid “A” maps, TorqSigGood means that the signal for the ECU to reduce torque during gearshift is working correctly. If the signal stops working a different set of maps is used to cope with the full torque during the gearshift.
The QC fools the TCU into thinking that the torque signal is working, even though the QC has in effect cut the signal wire. Therefore as a result, although the ECU is calling for full torque through the shift, the TCU remains using the normal half-torque maps, instead of the full-torque maps. I believe that this will make the clutches wear out prematurely."
Old 02-07-2019, 01:23 AM
SURTEESS's Avatar
When I got my gearbox rebuild late last year, the mechanic sent it to Hamilton and got the clutch pack watercut from kevlar - also noting that the final drive set was increased from 0.8mm each to 1.0mm in thickness, so less takeup slack.
The gearbox after the rebuild was amazing, with slick gear changes and no slippage - especially in manual mode.
Since then I have had the TCU ROM upgrade and the "other" black box fitted that i sell as a kit (PCB supplied, other components bought by owners and fitted by them).
The engine now revs much quicker to red line due to remapping of ROM, and the take off from a standing start is quicker than the Audi TT 1800 Turbo that my partner has......these changes together with the uprated suspension means the car is a different beast - and I don't want to change it to a manual gearbox.
Old 02-08-2019, 08:10 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
I ran a 13.6 last season with 4.44 and nitrous
[SIGPIC][/SIGPIC]
Old 02-16-2019, 01:14 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Post up a pic of the time slip and you’re on the list! 😎
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-16-2019, 01:59 PM
I dont have tranny issues is what im saying. I don't even remember when i was told about it or i wouldn't have run it in fwd but 34k miles since that post and no tranny issues. Although i did see a reman sticker on it, so it has been replaced and i wasn't doing it any good running it in fwd. Its in awd now
Old 02-23-2019, 02:38 AM
jman050's Avatar
Its a Classic!
Here ya go hope this works
[SIGPIC][/SIGPIC]
Old 02-23-2019, 01:59 PM
svxnavyvet svxnavyvet is offline
Do you have the ability to add paddle shift ?
Originally Posted by surteess View Post
when i got my gearbox rebuild late last year, the mechanic sent it to hamilton and got the clutch pack watercut from kevlar - also noting that the final drive set was increased from 0.8mm each to 1.0mm in thickness, so less takeup slack.
Since then i have had the tcu rom upgrade and the "other" black box fitted that i sell as a kit (pcb supplied, other components bought by owners and fitted by them).
The engine now revs much quicker to red line due to remapping of rom, and the take off from a standing start is quicker than the audi tt 1800 turbo that my partner has......these changes together with the uprated suspension means the car is a different beast - and i don't want to change it to a manual gearbox.
Old 02-23-2019, 05:15 PM
"I have had the TCU ROM upgrade"
Exactly how does this alter the time frame and the sequences in respect of line pressure and in particular, the control of engine torque? I would expect the details to have been published.
Display Modes Rate This Thread
Rate This Thread:
