#76
Re: TURBOs!?
#77
Re: TURBOs!?
Thanks for the insults .
I never claimed to be an expert, but thanks for the advice jackass. |
#78
Re: TURBOs!?
#79
Re: TURBOs!?
The only ecu I want to run is the stock setup, tuned by LAN. So, not sure where you thought I was running a different ecu at. Weird about the turbo, I've asked several people with tuning experience after explaining my goals, they have said that a GT30r would work, but would have very little overhead compared to a GT35r, but that for my application it would be great. I'm all for learning, which is why I stalk Harvey's past posts . I have no intention of wasting money, so if you have knowledge to enlighten me with, do it. If not, leave me alone and I'll fall from the nest, get back up and flap my happy ass to clearer sky's. *edit* After doing some more reading in the cam threads. Utilizing the iris valve with stock cams would achieve my goal. As far as making power at 7k rpms. Well, I'll save that for the rebuilt EG33 I plan on doing this coming summer. At that point, I'll have enough for custom cams and such. Quote:
#80
Re: TURBOs!?
#81
Re: TURBOs!?
What has been shown over the years, that the turbo has been tried on the EG33, is that its the exhaust pipes that cause it to die at 5000.
The early ones used or copied a kit that was around at that time. This kit had the two engine pipes joined together then going to the turbine. This caused interference between the cylinders so that a cylinders overlap would be pressured by the exhaust pressure from the previous cylinder. The fix was to run the two engine pipes right up to the turbine before they joined. When this was done the engine ran up the range OK. This is the problem with turbos on a six cylinder engine, and why twin turbos are the go on sixes. Harvey.
#82
Re: TURBOs!?
#83
Re: TURBOs!?
I want the instant punch of boost, so going larger than an GT35r remote mount would be pretty dumb imho. I guess when the time comes I'll have to sit on the phone with garrett and talk... |
#84
Re: TURBOs!?
This is because the MAF he has the stage 2 chips calibrated to run on can only flow enough air for up to 500 HP.
'92 SVX LS Pearl White - 6mt |
#85
Re: TURBOs!?
If I ever want to push that high it will be with a fully built engine. Thanks for the post!
#86
Re: TURBOs!?
500 hp is unrealistic for one of LAN's stage 2 chips. The 370cc injectors ought to max out at (recalling from memory here) just under 400 hp. Maybe can squeeze out a bit more if you bump up the pressure with an adjustable FPR.
The stage 3 chip used two MAFs and 550cc injectors and could do 500 hp probably. But you are definitely better off going with a standalone, that is tuned for the specific engine/setup you have. Much safer to run it that way too.
#87
Re: TURBOs!?
#88
Re: TURBOs!?
That would be right, I make a statement of fact, you tell me “This is incorrect.” then go on and tell us how a different engine runs, accompanied by a lot of irreverent stuff that tells me that you obversely don’t understand how the system works, so I will be nice and explain it to you.
When the two engine pipes are connected close to the manifolds, the cylinders on each side are pressurising the exhaust system every 120*. This means that when a cylinders exhaust valve opens to evacuate its cylinder at 60* BBDC, and the piston has progress to 60* ABDC, the next cylinder opens its exhaust valve to push gas into that cylinder. This can be handled as the piston will push this gas back out the exhaust port, and as long as the boost pressure is higher than the exhaust pressure it will continue to induct air/fuel and keep running. But as the rpm and boost pressure, and exhaust volume rises, the exhaust pressure exceeds the boost, and the piston then pushes the exhaust gas into the inlet manifold to foul the charge, and the engine goes flat. To prevent this we have to have the engine pipes long enough before they join, so that by the time that gas gets to the next cylinder, its exhaust valve has closed and it is not affected. It is this fact that makes car designers to use two turbos on a six. If they were to use the long engine pipes that a single needs, they would loose too much energy from the gas. Mounting one on each pair of three exhaust manifolds has the highest energy applied to the turbine, with no interference. Now looking at what you have said. Quote:
If you looked into this engine you would have found that the inlet cam timing up to 5000 is, Opens 47* BTDC closes 23* ABDC. This timing will only make the situation worst, as with the inlet valve open so early, the piston will push the gas back into the inlet manifold. When the cam goes to retard, the inlet valve timing is, Opens 3* ATDC, Closes 73* ABDC. With this timing the exhaust valve closes as the inlet opens, so the interference will not happen. So it is no wonder that the engine started to work at 5000, but you in your wisdom have decided that it was just a case of using a longer duration, so you will copy that, with out knowing what it is all about. Quote:
#89
Re: TURBOs!?
#90
Re: TURBOs!?
I don’t want to mislead anyone.
The first turbo that was on the net was Chucks on yahoo around 99. This had the problem of the engine going flat and the manifold boost pressure spiking, there was another one but can't remember who. Years later when Phil was going to do his, we were talking about it on a thread, and he said that he was going to do his, with the two engine pipes going right up to the turbine. The result was his Quote, that I posted. “E85 and 15lbs of boost. It is rediculous. No knock and more power you could ever dream of. Slow burning so less tensile pressure than gasoline and cool at RBT. No need to build a motor for thousands of dollars with this kind of performance and tourqe. unbelieveable.....it pulls to redline as it should. its running about 11.7:1 in the upper rpm range.” Both of these engine were basically stock, the different header pipes made the difference, and yes I based my Fact on that, but it was factual enough for me. As for the rest, you say “Now the EZ30 and the EG33 run the EXACT same firing order. They run the same port design intake and exhaust and the engines are VERY similar.” The EZ30 is very similar, the same inlet manifolding, same valve timing, but you show a picture of a EZ30R engine that has the variably valve timing. This is the engine that Perrin is using. Nothing like manifolding or the fixed valve timing of the EZ30 or EG33. So when you go telling people, “that they don’t know anything and to learn from you”?? Harvey.
Thread Tools | |
Display Modes | Rate This Thread |
