Old 10-01-2007, 07:40 PM
Originally Posted by SVXBart View Post
YT!
1st of all how do you have 3 hands???
Third hand is mine!!!
SHHHHHH I thought Tom had an edge for a minute!
Old 10-01-2007, 08:44 PM
Originally Posted by immortal_suby View Post
Great mods! Seat of the pants I could tell a difference in body roll around my favorite corners going to and from work today. It's amazing something that small would make that much of a difference. Well worth the money and time, Thanks OT!
When I first did this mod I had to PM some of the "Inner Circle" to express my suprize at the effects of this lowley mod.
I named the PM, "Something Strange" because it was
strange/weird/wonderful to have such a responce from such a small mod!
Old 10-03-2007, 08:05 AM
GTOSVX, Marisa, and Mike621 stuff sent!
Thanks.
BTW, here is a link to the fifteen Minute, $15.00 Mod thread.
http://http://www.subaru-svx.net/for...e+%2415.00+Mod
Old 10-03-2007, 08:57 AM
so.... we're doing mine on the 27th??
Old 10-03-2007, 09:40 AM
It's Just Eric's Avatar
Missing in action
Got mine a few days ago....Man, I hate to see what you do to christmas presents!
Needless to say it was well packaged. Im picking up my rear sway bar bushings today, and probably installing both tomorrow.
R.I.P Cool Signature.
Old 10-03-2007, 10:21 AM
UPDATE: Additional photos added to the installation post above.
Old 10-03-2007, 10:29 AM
YT!
And please tell us, just where is your other hand and what is it doing...?
It better be holding the camera!
Old 10-03-2007, 07:33 PM
SVXBart SVXBart is offline
No John,camera was in Diana's hands!
I had beer in mine
Bart
Old 10-03-2007, 07:35 PM
I had beer in mine
And all was right with the world!
Old 10-09-2007, 12:20 AM
green_eyed_lady's Avatar
green_eyed_lady green_eyed_lady is offline
Nah, he doesn't wrap Christmas presents that way, we don't have enough tape to wrap a full set of rotors and stainless steel lines (my Christmas present in 2005).
Isn't he romantic? Nothin says lovin' like auto parts!
Diana
1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint
Old 10-12-2007, 10:49 AM
shotgunslade's Avatar
The install is done. 20 minutes was about right, even for someone as wrench-klutzy as me. One question, the how-to says to torque the bolt to 35 ft-lbs. Unfortunately, the only torque wrench I have is the big one I use to torque my lugs. How critical is this number, and, if it is critical, what would you suggest I use to set it. Right now, they are exactly "pretty tight." meaning I didn't lean on the wrench real hard, but used some force.
I'm going up to Watkins Glen this weekend for a 2 day DE event with NASA-NE, will let everyone know if I notice any difference. Hopefully, the rear-end will not become so loose that I have a return of the dreaded full-throttle corner exit oversteer. Watkins Glen with miles of Armco is not the place for that to happen. I did have the car aligned by a non-dealer, who actually used my rear camber bolts to give me 1.5 Deg negative at the rear. I'm now running 1.25 negative at the front with the new 245/40-17 RE01-R's.
Thanks very much, Tom. I'm really looking forward to testing them.
Old 10-12-2007, 10:55 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Dan,
If your knuckles were starting to turn white when you tighten down, then you're fine I didn't read back through the thread, but are the nuts self locking (nylocks)? If they aren't, I'd suggest replacing them - given the driving you do
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-12-2007, 10:59 AM
They are nylocks. I wasn't worried about them coming off so much as having too much friction, if they were too tight, between the bushing end and the bracket on the rod.
Old 10-12-2007, 11:02 AM
SVXRide's Avatar
don't think you'll have a problem unless you tightened down so much that the end link's u-end started to distort.
-Bill
Old 10-12-2007, 11:08 AM
The movement of the bar will overpower any over tightness of the bolt.
I would suggest that you try it out,IN A SAFE LOCATION before you hit the track!
Good luck and have fun!
