#31
Re: all interior lights dont work
Always remove a fuse and check for continuity . Sometimes they look perfect . I got burnt too many times by not doing that . I learned that the hard way. Checked a fuse visually, looked good and spent 2hours looking for trouble only to go back and find it was the fuse all along
I believe everyone will agree that above statement ? Last edited by Conn SVX; 12-17-2011 at 10:00 PM. |
#32
found the source of the blown fuse, clutch pedal piece was starting to cut into the wiring harness :S
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
#33
Don't you just love a happy ending? ![]() A lot of patience and a little electrical tape and suddenly all is right in the world. Glad it was such a simple fix. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
#34
Re: all interior lights don't work
#35
ya it was also my issue for the stiff clutch pedal
#36
My clutch pedal was starting to cut through the same bunch of wires, but luckily I caught it before anything happened.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#37
wtvr got cut didnt affect anything that i knew of just a lot of stripped wired which when i clutched in blew the fuse under the hood.
took the pedals off and cut that piece off, dunno what that extension with the hole in it was for i'm guessing a resistance spring holder?
Thread Tools | |
Display Modes | |
