#406
Re: Wheels that fit the SVX
Still using 2005+ STi spindles should be done with its matching 6spd as this minimizes the needed new parts outside of the donor car. |
#407
18x8 wheels from an 2008 STI fit Beautiful. I just slipped these shoes on today. Stock height suspension. Tires are 245/40r18. Zero clearance issues. Go get'em fellas.
Im SOoooo happy with how these turned out. |
#409
^ Those look great. Neat paint job too.
#410
Not a HUGE fan of gold but on that car it works . Maybe because the teal or the wheels are not the real brass GOLD
#411
Gold seems to work well with the teal color. It was either that or I was going to go black like the top of the car. But it seems to complete the car with that paint.
It nice to have my ol'SVX back again Missed it so much. |
#412
'05 Sti wheels: 17x8 BBS, 55 offset, bought online for about $850 with shipping. Not a scratch on them.
Continental Extreme Contact DWS 235/45 17. No rubbing except when I hit a very big dip, the rear taps the inner plastic wheel well. Very happy with the look. Wasn't sure I would be as I was looking at SSR Professors but glad I saved the $ for other mods later. So far, the Conti's are great. Snow/ice should put them to the test soon. http://www.cardomain.com/ride/393738...x-lsi-coupe-2d |
#413
Wonder if anyone can help ID these wheels... I've checked American Racing sites and been through this thread...can't find which model AR wheels these are... I pulled them off a 92 in a pick and pull here in Salt Lake. They are 17" the tires on them...vary from 235/45 R17 94H p215/50 R17 93v (and finally ) 235/45Z R17 94W
(wonder why it was in the junk yard?)
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
#414
Those look really familiar. I think I was looking at a set of those a couple years ago. I can't remember what they're called, but if they're the ones I think they are, they're actually half-decent considering the brand.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
#415
Will 17x8's with 225/45/17 and +48 offset fit?
#416
Probably. I have 17x8 with 225/45/17 and +42 offset, and there is still some room. I should note that it's on lowered coilovers as well - still fits
#417
Thanks! There's a set of rota's wrapped in fresh allseasons for $800 i'm looking at.
#418
Can anyone help,
Looking at a very nice set of rims used with good tires. Size of the rim is 18 X 8.5 with a +50 offset and 114pcd Tires are a Bridgestone RE01-R 235/40/18 Would these fit ok without rubbing issues? Please anyone?
1986 4WD Turbo XT coupe 5sp.(XTINCT) 1987 4WD Custom Turbo XT coupe (XTLUNAC) 1992 SVX LS-L (LUNACY) former: 1991 4wd XT6 5sp. (SUBDUED) |
#419
I can't say for sure, but my gut tells me that would be a tight fit - those are some wide rims, and with a +50 offset, they might not clear your suspension. Also, if your suspension is stock, they might rub on bumps.
This is all just a guess on my part though. I run an 8" wide rim with a +42 offset and I get no rubbing or clearance issues, but those tires are a half inch bigger diameter and slightly wider than mine, so I can't say for sure. There are lots of folks on here that have mounted 18s in the past, but usually narrower rims. The stock 18s from the Nissan Murano were briefly popular, for example. All I can suggest it try them out and if they don't fit, resell them
#420
I think if you went with a lower sidewall, maybe go down to a 225/4018 which is the close to the stock rolling size you may be ok. or if you want the 235/ or even 245/ go with a 35 sidewall looking at tire size calc http://www.1010tires.com/TireSizeCalculator.asp I think 245/35/18 may be perfect for you, the overall diameter will be .10 inch smaller then stock which will gain you a bit of clearance and keep the wider rim happy at the same time. Last edited by 92 SVX; 11-04-2011 at 03:45 PM. |
Thread Tools | |
Display Modes | |
