#91
Re: SVX Straight line performance
![]() ![]() ![]() ![]() ![]() But fwd burnouts are teh koolest! ![]() |
#92
#93
Youse Guys are just mean!
www.svxfiles.com The first SuperCharged SVX, ![]() the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway ![]() Fiberglass Hood thread My locker 4.44 Swap link |
#94
My car (The SVreX) ran 13.8 at the Grassroots Motorsports Challenge in 2004. It was AWD stock slushbox and gears. It was pretty stripped, and had a 75 shot of nitrous. Never tried to do better, but I see no one else has either! ![]()
'92 LS-not-so-L: the "SVreX"- Saved from a crusher, an SVX racer built by home schooled students for less than $2000 (including purchase price). 13.8 second 1/4 mile. Autocrossing monster!! ![]() '92 LS-L Claret: '01 RS 4:11 5-speed, Exedy organic, lightened flywheel, and Koni/ GC ![]() |
#95
Man, I haven't been on here in years, use Facebook now. Anyway 8 years later and still using fwd about 95% of the time, no problems yet. Tranny wise, plenty other though
92 claret-87 xt turbo-93 z28 6 speed-06 cobalt SS |
#96
It's so crazy to think you can drive the car in FWD for eight years and nothing happens. That couldn't have caused your transmission issues?
#97
What about cars with the Gear Firm-Up Unit (QC) added ???
OR The Power Mod ???
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 02-05-2019 at 01:57 AM. |
#98
" Within the solenoid “A” maps, TorqSigGood means that the signal for the ECU to reduce torque during gearshift is working correctly. If the signal stops working a different set of maps is used to cope with the full torque during the gearshift. The QC fools the TCU into thinking that the torque signal is working, even though the QC has in effect cut the signal wire. Therefore as a result, although the ECU is calling for full torque through the shift, the TCU remains using the normal half-torque maps, instead of the full-torque maps. I believe that this will make the clutches wear out prematurely."
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 02-05-2019 at 04:25 PM. Reason: Addition |
#99
When I got my gearbox rebuild late last year, the mechanic sent it to Hamilton and got the clutch pack watercut from kevlar - also noting that the final drive set was increased from 0.8mm each to 1.0mm in thickness, so less takeup slack.
The gearbox after the rebuild was amazing, with slick gear changes and no slippage - especially in manual mode. Since then I have had the TCU ROM upgrade and the "other" black box fitted that i sell as a kit (PCB supplied, other components bought by owners and fitted by them). The engine now revs much quicker to red line due to remapping of ROM, and the take off from a standing start is quicker than the Audi TT 1800 Turbo that my partner has......these changes together with the uprated suspension means the car is a different beast - and I don't want to change it to a manual gearbox.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 02-13-2019 at 05:05 PM. |
#100
I ran a 13.6 last season with 4.44 and nitrous
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
#101
Post up a pic of the time slip and you’re on the list! 😎
#102
I dont have tranny issues is what im saying. I don't even remember when i was told about it or i wouldn't have run it in fwd but 34k miles since that post and no tranny issues. Although i did see a reman sticker on it, so it has been replaced and i wasn't doing it any good running it in fwd. Its in awd now
#103
Here ya go hope this works
#104
Do you have the ability to add paddle shift ?
Exactly how does this alter the time frame and the sequences in respect of line pressure and in particular, the control of engine torque? I would expect the details to have been published.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 02-23-2019 at 05:23 PM. Reason: Addition |
Thread Tools | |
Display Modes | Rate This Thread |
